12745 Discussions
Help: assemble langurage development
I want to develop nios ii firmware using assemble langurage. The firmware will run in the onchip_memory. My questions are,
1), how to deside the sp address?
2), how to set the exception address in SOCP?
eRen
- the stack grows towards lower memory, so put it at the highest accessible memory location.
- setting the exception address can be done in the second tab sheet of the SOPC builder
Stefaan
eRen,
setup of the stack pointer is made in file crt0.s. Copy this file from &#39;<NIOS-Dir>\components\altera_nios2\HAL\src\&#39; to your software directory and make your changes. If the compiler finds this file in your directory it is not searched further.
Mike
Thanks Mike and Stefaan.
eRen
