12745 Discussions
8 bit dynamic alignment for SPI device?
Hello!
I've designed controller for NVRAM memory with SPI interface.
I've create component as memory slave device with 8 bit data bus (I don't want to use
this as register slave).
When I write to memory all is OK (address, cs, write signals are correct), but when I was tried to read
address bus is wrong.
For example:
unsigned char *p = (unsigned char*) FRAM1_BASE;
int main(void)
p[0] = (unsigned char) 0xDC;
printf("%02x\n", (unsigned char) p[0]);
p[1] = (unsigned char) 0xCD;
printf("%02x\n", (unsigned char) p[1]);
return 0;
I've simuleted it and got next:
When to p[0] or p[1] I write some value it is writing correct,
but when it is reading - address bus sets to 0, after to 1, after to 2, after to 3 (in both case).
All this time chipselect is active and read signal too.
Therefore when I'm reading p[1], there always p[0], because p[0] was read first.
What's wrong?
Any idea?
Thx.
Hi Camelot,
I think this behaviour is caused by the "memory slave" setting. Infact your peripheral is 8 bit wide and, in order to read a 32 bit word, the Avalon bus has to do 4 reading from your peripheral.
How many registers has your peripheral and what's address span?
My SPI memory has 65536 8-bits cells and has a span from 0x01010000 to 0x0101FFFF.
In my core I'm reading 16-bits address and 8-bits data from avalon bus and write these values by spi interface to memory. The reading is doing similarly (reading address).
All this time when data writing or reading signal chipselect, write or read is keeping on Avalon bus fixed time.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
When to p[0] or p[1] I write some value it is writing correct,[/b]
--- Quote End ---
What do you mean? What address signals can u see when writing p[0] and p[1]?
When I write to p[0] address is 0, when I write to p[1] address is 1.
Ok,
I think you have to use "register slave" setting for your component: in this case you will have 0x40000 address span, but you will access a single byte cell when reading.
Thanks for replay http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Point is that I want to lighten the work of a programmer and a complexity of programm.
Nevertheless, maybe the solution is near here?
For reading, have you tried "IORD_8DIRECT(FRAM1_BASE,0)" for p[0] and "IORD_8DIRECT(FRAM1_BASE,1)" for p[1]?
Are you read my mind ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif I&#39;m trying it write now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
But all the same http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Yes,
I have this skill http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
