A debug problem!
I had buid a system in SOPC Builder 5.0 with NIOS II/F, JTAG level 3, 16KBytes onchip_rom, 1KBytes exchange_ram, jtag_uart.
In NIOS IDE, I compiled a sample project hello_world_simple, this project could run properly on target hardware, how ever, if I debug this project, the console shows :
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Processor is already paused
Listening on port 2874 for connection from GDB: 59s58s57s56s55s54
saccepted
Connection from GDB closed
Leaving target processor paused;
I'm using cyclone epIC12Q240C8, with 80 MHz clock and Byteblaster II.
btw,when i debug the ISS ,it shows :
Error! : The ELF file Debug/hello_world_0.elf is attempting to load a larger mem
ory block (size = 0x455C) than has been defined for module exchange_ram (size =
0x0400) in the ptf file
Fatal Error! : Memory map is not consistent with memory image file - check that
file 'Debug/hello_world_0.elf' is compiled and linked for system 'D:\RESET_SOPC_
PCI3\Hard_Emulator.ptf'
could anybody help me!?
with my regards!
It seems to be that you're trying to put into your RAM a block of code/data which is bigger than it's size.
Besides this, with a -C8 speed grade chip, can you run a NIOS-II at 80MHz? Doesn't your Quartus give warnings about not meeting your timing assignments? We use an EP1C12, 324pins, -C8, NIOS-II, near 89% resources usage (lots of things in hardware) and our highest speed is about 70MHz.
i add a PLL to improve the clock !the input is 25M
