A problem of using sdram
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
Hi all,
I found a problem of using sdram as stack memory
(configured in the sys lib properties in the NiosII IDE(5.0e)).
When I configured all the type of memory in the sys lib properties into "sram",
everything went pretty ok, and when I changed the configuration of heap momory
into sdram,it was still all right;however,when I converted the
selection for stack memory from sram into sdram(that meaned the stack memory
and heap memory were all in sdram at the moment),my program went out of order! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
You see,this is the result when I ran count_binary.c in NiosII IDE:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
* Hello from Nios II! *
...(some starnge codes continue here,I can not copy them here,
it seems the BBS does not support displaying those codes)
nios2-terminal: exiting due to ^D on remote
But infact the result should not be like this,and I did see the
should-be correct result when I configured stack memory as sram previously.
So could anyone give me some tips about that?
Thanks in advance!
which board? Altera NDK or custom board?
How do you deal with the sdram&#39;s "clock"?
It will be helpful to search "sdram" in the BBS. Lots of threads talked about this issue.
Just like mountain was saying you may have to put a phase shift on the SDRAM clock (it&#39;s best to think of it as a time shift though). If you look at any of the standard or full featured hardware reference designs installed with Nios II you&#39;ll see the shift I&#39;m talking about (note that shift isn&#39;t necessarily the same amount that you need if you are using a custom board).
Also if you have Nios II 5.0, try opening the SSRAM memory component and click on the link to the readme.txt file for it (or find it in the documentation folder). It gives a really good explination about the phase shift needed for SSRAM and the theory can be carried over to SDRAM.
Thanks mountain and Badomen,but I did
have a PLL used for converting the clk signal of sdram. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
Today I found a new problem of using sdram:
When I configured the components of my design in SOPCBuilder
as a "minimum system"(only has sram,sdram,and flash,no other user peripherals),
and I confugured all the mem choices in sys lib properties as sdram,
I found it work normally! So I think the sdram of my design should
be out of problems...
However,when I added user peripherals into the same SOPCBuilder,
such as uart and pio, and regenerated the whole system,
and builded the same file under NioII IDE,the sdram
does not work and "paused" after pressing "run as NIosII hardware" !
But when I removed all the user components I just added into my design,
only left it as the "minimum configuration" as the first time,
and gave it another regeneration.This time,
when I builded the same design as the last two times,
the sdram worked normally again! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
So I have to speculate that it is the user peripheral
result in the problem of the function of sdram in my design.
Am I right?Does someone have any suggestions about my
speculation?
Many Thanks!
