12748 Discussions
Problem with debugging assembly code with NIOS II
I have an assembly file that looks like the following:
#include "nios2.h"# include "system.h"# include "cpu_const.h"     .extern    tmp_space       .section .text 1        .global _cpu_task_start 2   _cpu_task_start: 3        movia    r22, tmp_space 4        movia    r23, REGISTERS_OFFSET 5 _cpu_task_loop: 6        ldbio    r21,status_offset(r23)     7        andi    r2,r21,status_rec_bit 8        beq    r2,r0, koniec_rec     ...................        and so on
And I have c code witch calls this function
9        _cpu_task_start();
Everything compiling and linking ok. It seems to work ok too. But if I try to debug it with NIOS II IDE, I can't debug assembly function.
When debugger stops on line 9, debugging work fine, I see source code window and disassembly window. When I try to do “Step Into” debugger stops at the first line, but I can see it only on disassembly window, the source code window still remain on line 9
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Disassembly window
0x01000594 <_cpu_task_start>:    movhi r22,257
0x01000598 <_cpu_task_start+4>:  addi  r22,r22,11376
0x0100059c <_cpu_task_start+8>:  movhi r23,160
0x010005a0 <_cpu_task_start+12>: addi  r23,r23,512[/b]
--- Quote End ---
In this way, I only can debug first two line of assembly code, line no. 6 is unreachable.
(Debugger dont stop, if I suspend, it stops in C code, much more ahead).
If I set a breakpoint in line 7, the debugger stops in entirely different function “alt_irq_init”.
It seems for me, that debugger doesn&#39;t see my test.s file.
Pleas help, what can I do to debug it in normal way.
The assembly part of start up code is debugging fine.
I&#39;ll be appreciate for any advice.
I use NIOS V5.0.
Darek
