12745 Discussions
Again function with "attribute"
Hi all,
I have Quartus 4.2 Nios 1.2, my system:
- Nios II (e), no debug module, 32 MHz
- onchip_memory 4096 bytes RAM
- onchip_memory_2 1024 bytes RAM
- instruction and data bus connected to onchip_memory and onchip_memory_2
- EPCS controller
- reset address,exception address, break location = onchip_memory
- program and data memory = onchip_memory
- i have used all the compilation settings to reduce code footprint as explained in "Developing Programs using the HAL" chapter
if a define a function with:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
__attribute__ ((section ( ".onchip_memory_2")))[/b]
--- Quote End ---
my CPU hangs when this function get called. Every fuction I define with "attribute", the same behaviour.
Any suggestions?
thank u
