12748 Discussions
Altera JTAG UART used by kernel does not match IRQ assignment made in Qsys
Hi all,
I'm currently developing a 3.10.31-ltsi kernel that running on a Nios II-based system. This system also contains several components including an Altera JTAG UART, USB host controller and a timer.
In Qsys, I assigned the following Nios II interrupts for these system components:
jtaguart: IRQ 0
timer: IRQ 1
usbhc: IRQ 2
The device tree binary (.dtb), U-boot and the kernel are built using these assignments and stored to flash.
However, when the kernel boots, the interrupt for the Altera JTAG UART is remapped to IRQ 2 as seen in the following KERNEL DEBUG message:
ttyJ0 at MMIO 0x1001840 (irq = 2) is a Altera JTAG UART
When this happens, the kernel is no longer able to attach the USB host contoller (usbhc) to IRQ 2 and the following error messages come up:
genirq: flags mismatch irq 2. 00000000 (altera_jtaguart) vs. 00000080 (sls-hcd: usb1)
altera_jtaguart: unable to attach altera jtag uart 0 interrupt vector=2
I have some questions about this process that I'm hoping someone can explain:
- When the Altera JTAG component / device is added, why is the interrupt remapped from IRQ 0 to IRQ 2?
- Why isn't the usbhc controller remapped from IRQ 2 to something else?
In addition, when I forced the Altera JTAG UART interrupt to IRQ 0 to match the Qsys setting by modifying the altera_jtaguart driver, when the kernel attempts to attach IRQ 0 to the JTAG UART, the following error message was displayed:
altera_jtaguart: unable to attach Altera JTAG UART 0 interrupt vector=0[/I][/I]
However, the usbhc component was correctly added and attached to IRQ 2 as indicated by the following message:sls-hcd sls-hcd.0: irq2, io mem 0xe1008000[/I][/I]
Any feedback that would help explain what is happening with these interrupts during the kernel booting sequence would be appreciated.
- Brad
Hi Bhaumik,
Thank you for all the useful information from your testing. Based on your results, it does appear that IRQ 0 is reserved for something internal and shouldn't be assigned any Qsys component. We have seen similar results in our testing but I didn't perform any methodical tests like the ones you performed. I appreciate you sharing the results.
While it appears that IRQ 0 is reserved for something internal, I was unable to find any documentation that confirms what your test results. I would think that if IRQ 0 is reserved and should be left open then it should be documented somewhere to prevent the interrupt remapping confusion between Qsys and the Linux kernel. Although given, our test results, I will avoid assigning IRQ 0 to any Qsys component in the future when using a Linux OS.
I just returned from vacation so I'm going to catching up on a few items but I hope this will help resolve the interrupt remapped issue(s) I have been seeing. If I have any additional information based on my testing, I will let you know.
Thanks again for your help.
- Brad
