12748 Discussions
Altera SOPC Builder problem
Hello ,
I've got a problem with the Altera SOPC-Builder. Below error occurs in the SOPC, when I try to generate the code (from Nios II tutorial):
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Altera SOPC Builder Version 5.00 Build 148
Copyright © 1999-2005 Altera Corporation.  All rights reserved.# 2005.06.11 16:49:44 (*) mk_custom_sdk starting# 2005.06.11 16:49:44 (*) Reading project C:/altera/kits/nios2/tutorials/niosII_custom_instr_tutorial/niosII_stratix_1s10/quartus_project/system.ptf.# 2005.06.11 16:49:44 (*) Finding all CPUs# 2005.06.11 16:49:44 (*) Finding all available components
no install.ptf file found at C:/altera/quartus50/sopc_builder/bin/europa/europa_utils.pm line 1758.
Error in processing.  System NOT successfully generated.[/b]
--- Quote End ---
Any ideas?
mehaw
Installation and/or user issue of some sort. Be sure that you&#39;re using Quartus/SOPC Builder as the same user that installed it. The "install.ptf" file is in ~/.sopc_builder/install.ptf (where ~ represents the user profile directory in Windows and the user&#39;s home directory in Linux/UNIX). If running on Linux/UNIX, you need to make sure that whatever user you&#39;re logged in as, actually has a home directory.
- slacker
Thanks a lot!
The problem was name of user account. I&#39;ve got Polish Edition of Windows XP, and there was Polish national character in name of user. I had no problem with it for years. But for SOPC it was http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Thanks you, once again.
Mehaw
