Hello ,
I've got a problem with the Altera SOPC-Builder. Below error occurs in the SOPC, when I try to generate the code (from Nios II tutorial): <div class='quotetop'>QUOTE </div> --- Quote Start --- Altera SOPC Builder Version 5.00 Build 148 Copyright © 1999-2005 Altera Corporation. All rights reserved.# 2005.06.11 16:49:44 (*) mk_custom_sdk starting# 2005.06.11 16:49:44 (*) Reading project C:/altera/kits/nios2/tutorials/niosII_custom_instr_tutorial/niosII_stratix_1s10/quartus_project/system.ptf.# 2005.06.11 16:49:44 (*) Finding all CPUs# 2005.06.11 16:49:44 (*) Finding all available components no install.ptf file found at C:/altera/quartus50/sopc_builder/bin/europa/europa_utils.pm line 1758. Error in processing. System NOT successfully generated.[/b] --- Quote End --- Any ideas? -- mehawLink Copied
Installation and/or user issue of some sort. Be sure that you're using Quartus/SOPC Builder as the same user that installed it. The "install.ptf" file is in ~/.sopc_builder/install.ptf (where ~ represents the user profile directory in Windows and the user's home directory in Linux/UNIX). If running on Linux/UNIX, you need to make sure that whatever user you're logged in as, actually has a home directory.
- slacker- Mark as New
Thanks a lot!
The problem was name of user account. I've got Polish Edition of Windows XP, and there was Polish national character in name of user. I had no problem with it for years. But for SOPC it was http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thanks you, once again. Mehaw
