12745 토론
An error occurred while executing the "make" command in order to create preloader file
AWan01
Partner
1,781 조회수
I'm trying to compile a new preloader file using SOC EDS 15.0 on win10, but an error occurred while executing the "make" command.
tar zxf /cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
tar: Error opening archive: Failed to open '/cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz'
make: *** [uboot-socfpga/.untar] Error 1
0 포인트
4 응답
EBERLAZARE_I_Intel
1,631 조회수
Just to confirm, have you run the SoC EDS as admin? You can right click and select "Run as Admin".
The error pops up after the make often causes by the file is not accessible, thus you need to run the SoC EDS as admin.
If this does not fix the issue let me know.
0 포인트
EBERLAZARE_I_Intel
1,631 조회수
Do you have any followup from your side?
Regards.
0 포인트
AWan01
Partner
1,631 조회수
I have run the SoC EDS as admin, but it doesn't work. I don't understand what happened, but another way seems to work for me.
Commet out lines 219/220 of the Makefile in the spl_bsp folder.
# $(RM) $(PRELOADER_SRC_DIR)
# $(untar_recipe)
Run  tar zxf /cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
then executing the "make" command  from SoC EDS.
Thank you.
0 포인트
EBERLAZARE_I_Intel
1,631 조회수
It seems that the file is still in archive, that is the cause of the issue.
I recommend that you use the latest version of SOC EDS 18.1 std if you are using Cyclone V SoC.
0 포인트
응답
