12745 Discussions
Ashling RiscV NiosV errors
Fpga_Egr_2025
Hi I am trying to compile a simple hello world on NiosV targeting a CycloneIVE FPGA on DE2-115 board p/n : EP4CE115F29C7. But when i build project in Ashling RiscFree i get these errors which i dont have any idea what these referring to :
Below i am pasting the complete system.h file :
* system.h - SOPC Builder system and BSP software package information
* Machine generated for CPU 'Nios_gen_purpose' in SOPC Builder design 'SOC_uart'
* SOPC Builder design path: ../../SOC_uart.sopcinfo
* Generated: Tue May 27 13:03:27 PKT 2025
* DO NOT MODIFY THIS FILE
* Changing this file will have subtle consequences
* which will almost certainly lead to a nonfunctioning
* system. If you do modify this file, be aware that your
* changes will be overwritten and lost when this file
* is generated again.
* License Agreement
* Copyright (c) 2008
* Altera Corporation, San Jose, California, USA.
* All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* This agreement shall be governed in all respects by the laws of the State
* of California and by the laws of the United States of America.
#ifndef __SYSTEM_H_
#define __SYSTEM_H_
/* Include definitions from linker script generator */
#include "linker.h"
* CPU configuration
#define ALT_CPU_ARCHITECTURE "intel_niosv_g"
#define ALT_CPU_CLIC_EN 0
#define ALT_CPU_CPU_FREQ 50000000u
#define ALT_CPU_DATA_ADDR_WIDTH 0x20
#define ALT_CPU_DCACHE_LINE_SIZE 32
#define ALT_CPU_DCACHE_LINE_SIZE_LOG2 5
#define ALT_CPU_DCACHE_SIZE 4096
#define ALT_CPU_FREQ 50000000
#define ALT_CPU_HAS_CSR_SUPPORT 1
#define ALT_CPU_HAS_DEBUG_STUB
#define ALT_CPU_ICACHE_LINE_SIZE 32
#define ALT_CPU_ICACHE_LINE_SIZE_LOG2 5
#define ALT_CPU_ICACHE_SIZE 4096
#define ALT_CPU_INST_ADDR_WIDTH 0x20
#define ALT_CPU_INT_MODE 0
#define ALT_CPU_MTIME_OFFSET 0x00030000
#define ALT_CPU_NAME "Nios_gen_purpose"
#define ALT_CPU_NIOSV_CORE_VARIANT 3
#define ALT_CPU_NUM_GPR 32
#define ALT_CPU_NUM_SRF_BANKS 1
#define ALT_CPU_RESET_ADDR 0x00000000
#define ALT_CPU_TICKS_PER_SEC NIOSV_INTERNAL_TIMER_TICKS_PER_SECOND
#define ALT_CPU_TIMER_DEVICE_TYPE 2
* CPU configuration (with legacy prefix - don't use these anymore)
#define BANTAMLAKE_CLIC_EN 0
#define BANTAMLAKE_CPU_FREQ 50000000u
#define BANTAMLAKE_DATA_ADDR_WIDTH 0x20
#define BANTAMLAKE_DCACHE_LINE_SIZE 32
#define BANTAMLAKE_DCACHE_LINE_SIZE_LOG2 5
#define BANTAMLAKE_DCACHE_SIZE 4096
#define BANTAMLAKE_HAS_CSR_SUPPORT 1
#define BANTAMLAKE_HAS_DEBUG_STUB
#define BANTAMLAKE_ICACHE_LINE_SIZE 32
#define BANTAMLAKE_ICACHE_LINE_SIZE_LOG2 5
#define BANTAMLAKE_ICACHE_SIZE 4096
#define BANTAMLAKE_INST_ADDR_WIDTH 0x20
#define BANTAMLAKE_INT_MODE 0
#define BANTAMLAKE_MTIME_OFFSET 0x00030000
#define BANTAMLAKE_NIOSV_CORE_VARIANT 3
#define BANTAMLAKE_NUM_GPR 32
#define BANTAMLAKE_NUM_SRF_BANKS 1
#define BANTAMLAKE_RESET_ADDR 0x00000000
#define BANTAMLAKE_TICKS_PER_SEC NIOSV_INTERNAL_TIMER_TICKS_PER_SECOND
#define BANTAMLAKE_TIMER_DEVICE_TYPE 2
* Define for each module class mastered by the CPU
#define __ALTERA_AVALON_JTAG_UART
#define __ALTERA_AVALON_ONCHIP_MEMORY2
#define __ALTERA_AVALON_PIO
#define __ALTERA_AVALON_SYSID_QSYS
#define __ALTERA_AVALON_UART
#define __INTEL_NIOSV_G
* GPIO configuration
#define ALT_MODULE_CLASS_GPIO altera_avalon_pio
#define GPIO_BASE 0x100000
#define GPIO_BIT_CLEARING_EDGE_REGISTER 0
#define GPIO_BIT_MODIFYING_OUTPUT_REGISTER 0
#define GPIO_CAPTURE 0
#define GPIO_DATA_WIDTH 32
#define GPIO_DO_TEST_BENCH_WIRING 0
#define GPIO_DRIVEN_SIM_VALUE 0
#define GPIO_EDGE_TYPE "NONE"
#define GPIO_FREQ 50000000
#define GPIO_HAS_IN 0
#define GPIO_HAS_OUT 0
#define GPIO_HAS_TRI 1
#define GPIO_IRQ -1
#define GPIO_IRQ_INTERRUPT_CONTROLLER_ID -1
#define GPIO_IRQ_TYPE "NONE"
#define GPIO_NAME "/dev/GPIO"
#define GPIO_RESET_VALUE 0
#define GPIO_SPAN 16
#define GPIO_TYPE "altera_avalon_pio"
* Nios_gen_purpose_dm_agent configuration
#define ALT_MODULE_CLASS_Nios_gen_purpose_dm_agent intel_niosv_g
#define NIOS_GEN_PURPOSE_DM_AGENT_BASE 0x20000
#define NIOS_GEN_PURPOSE_DM_AGENT_CLIC_EN 0
#define NIOS_GEN_PURPOSE_DM_AGENT_CPU_FREQ 50000000u
#define NIOS_GEN_PURPOSE_DM_AGENT_DATA_ADDR_WIDTH 0x20
#define NIOS_GEN_PURPOSE_DM_AGENT_DCACHE_LINE_SIZE 32
#define NIOS_GEN_PURPOSE_DM_AGENT_DCACHE_LINE_SIZE_LOG2 5
#define NIOS_GEN_PURPOSE_DM_AGENT_DCACHE_SIZE 4096
#define NIOS_GEN_PURPOSE_DM_AGENT_HAS_CSR_SUPPORT 1
#define NIOS_GEN_PURPOSE_DM_AGENT_HAS_DEBUG_STUB
#define NIOS_GEN_PURPOSE_DM_AGENT_ICACHE_LINE_SIZE 32
#define NIOS_GEN_PURPOSE_DM_AGENT_ICACHE_LINE_SIZE_LOG2 5
#define NIOS_GEN_PURPOSE_DM_AGENT_ICACHE_SIZE 4096
#define NIOS_GEN_PURPOSE_DM_AGENT_INST_ADDR_WIDTH 0x20
#define NIOS_GEN_PURPOSE_DM_AGENT_INTERRUPT_CONTROLLER_ID 0
#define NIOS_GEN_PURPOSE_DM_AGENT_INT_MODE 0
#define NIOS_GEN_PURPOSE_DM_AGENT_IRQ -1
#define NIOS_GEN_PURPOSE_DM_AGENT_IRQ_INTERRUPT_CONTROLLER_ID -1
#define NIOS_GEN_PURPOSE_DM_AGENT_MTIME_OFFSET 0x00030000
#define NIOS_GEN_PURPOSE_DM_AGENT_NAME "/dev/Nios_gen_purpose_dm_agent"
#define NIOS_GEN_PURPOSE_DM_AGENT_NIOSV_CORE_VARIANT 3
#define NIOS_GEN_PURPOSE_DM_AGENT_NUM_GPR 32
#define NIOS_GEN_PURPOSE_DM_AGENT_NUM_SRF_BANKS 1
#define NIOS_GEN_PURPOSE_DM_AGENT_RESET_ADDR 0x00000000
#define NIOS_GEN_PURPOSE_DM_AGENT_SPAN 65536
#define NIOS_GEN_PURPOSE_DM_AGENT_TICKS_PER_SEC NIOSV_INTERNAL_TIMER_TICKS_PER_SECOND
#define NIOS_GEN_PURPOSE_DM_AGENT_TIMER_DEVICE_TYPE 2
#define NIOS_GEN_PURPOSE_DM_AGENT_TYPE "intel_niosv_g"
* Nios_gen_purpose_timer_sw_agent configuration
#define ALT_MODULE_CLASS_Nios_gen_purpose_timer_sw_agent intel_niosv_g
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_BASE 0x30000
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_CLIC_EN 0
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_CPU_FREQ 50000000u
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_DATA_ADDR_WIDTH 0x20
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_DCACHE_LINE_SIZE 32
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_DCACHE_LINE_SIZE_LOG2 5
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_DCACHE_SIZE 4096
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_HAS_CSR_SUPPORT 1
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_HAS_DEBUG_STUB
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_ICACHE_LINE_SIZE 32
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_ICACHE_LINE_SIZE_LOG2 5
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_ICACHE_SIZE 4096
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_INST_ADDR_WIDTH 0x20
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_INTERRUPT_CONTROLLER_ID 0
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_INT_MODE 0
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_IRQ -1
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_IRQ_INTERRUPT_CONTROLLER_ID -1
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_MTIME_OFFSET 0x00030000
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_NAME "/dev/Nios_gen_purpose_timer_sw_agent"
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_NIOSV_CORE_VARIANT 3
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_NUM_GPR 32
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_NUM_SRF_BANKS 1
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_RESET_ADDR 0x00000000
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_SPAN 64
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_TICKS_PER_SEC NIOSV_INTERNAL_TIMER_TICKS_PER_SECOND
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_TIMER_DEVICE_TYPE 2
#define NIOS_GEN_PURPOSE_TIMER_SW_AGENT_TYPE "intel_niosv_g"
* System configuration
#define ALT_DEVICE_FAMILY "Cyclone IV E"
#define ALT_ENHANCED_INTERRUPT_API_PRESENT
#define ALT_IRQ_BASE NULL
#define ALT_LOG_PORT "/dev/null"
#define ALT_LOG_PORT_BASE 0x0
#define ALT_LOG_PORT_DEV null
#define ALT_LOG_PORT_TYPE ""
#define ALT_NUM_EXTERNAL_INTERRUPT_CONTROLLERS 0
#define ALT_NUM_INTERNAL_INTERRUPT_CONTROLLERS 1
#define ALT_NUM_INTERRUPT_CONTROLLERS 1
#define ALT_STDERR "/dev/jtag_uart"
#define ALT_STDERR_BASE 0x30040
#define ALT_STDERR_DEV jtag_uart
#define ALT_STDERR_IS_JTAG_UART
#define ALT_STDERR_PRESENT
#define ALT_STDERR_TYPE "altera_avalon_jtag_uart"
#define ALT_STDIN "/dev/jtag_uart"
#define ALT_STDIN_BASE 0x30040
#define ALT_STDIN_DEV jtag_uart
#define ALT_STDIN_IS_JTAG_UART
#define ALT_STDIN_PRESENT
#define ALT_STDIN_TYPE "altera_avalon_jtag_uart"
#define ALT_STDOUT "/dev/jtag_uart"
#define ALT_STDOUT_BASE 0x30040
#define ALT_STDOUT_DEV jtag_uart
#define ALT_STDOUT_IS_JTAG_UART
#define ALT_STDOUT_PRESENT
#define ALT_STDOUT_TYPE "altera_avalon_jtag_uart"
#define ALT_SYSID_BASE NIOS_SYSID_BASE
#define ALT_SYSID_ID NIOS_SYSID_ID
#define ALT_SYSTEM_NAME "SOC_uart"
#define ALT_SYS_CLK_TICKS_PER_SEC ALT_CPU_TICKS_PER_SEC
#define ALT_TIMESTAMP_CLK_TIMER_DEVICE_TYPE ALT_CPU_TIMER_DEVICE_TYPE
* Uart_transciever configuration
#define ALT_MODULE_CLASS_Uart_transciever altera_avalon_uart
#define UART_TRANSCIEVER_BASE 0x80000
#define UART_TRANSCIEVER_BAUD 9600
#define UART_TRANSCIEVER_DATA_BITS 8
#define UART_TRANSCIEVER_FIXED_BAUD 1
#define UART_TRANSCIEVER_FREQ 50000000
#define UART_TRANSCIEVER_IRQ 1
#define UART_TRANSCIEVER_IRQ_INTERRUPT_CONTROLLER_ID 0
#define UART_TRANSCIEVER_NAME "/dev/Uart_transciever"
#define UART_TRANSCIEVER_PARITY 'N'
#define UART_TRANSCIEVER_SIM_CHAR_STREAM ""
#define UART_TRANSCIEVER_SIM_TRUE_BAUD 0
#define UART_TRANSCIEVER_SPAN 32
#define UART_TRANSCIEVER_STOP_BITS 1
#define UART_TRANSCIEVER_SYNC_REG_DEPTH 2
#define UART_TRANSCIEVER_TYPE "altera_avalon_uart"
#define UART_TRANSCIEVER_USE_CTS_RTS 0
#define UART_TRANSCIEVER_USE_EOP_REGISTER 0
* hal2 configuration
#define ALT_MAX_FD 32
#define ALT_SYS_CLK NIOS_GEN_PURPOSE
#define ALT_TIMESTAMP_CLK NIOS_GEN_PURPOSE
#define INTEL_FPGA_DFL_START_ADDRESS 0xffffffffffffffff
#define INTEL_FPGA_USE_DFL_WALKER 0
* intel_niosv_g_hal_driver configuration
#define NIOSV_INTERNAL_TIMER_TICKS_PER_SECOND 1000
* jtag_uart configuration
#define ALT_MODULE_CLASS_jtag_uart altera_avalon_jtag_uart
#define JTAG_UART_BASE 0x30040
#define JTAG_UART_IRQ 0
#define JTAG_UART_IRQ_INTERRUPT_CONTROLLER_ID 0
#define JTAG_UART_NAME "/dev/jtag_uart"
#define JTAG_UART_READ_DEPTH 64
#define JTAG_UART_READ_THRESHOLD 8
#define JTAG_UART_SPAN 8
#define JTAG_UART_TYPE "altera_avalon_jtag_uart"
#define JTAG_UART_WRITE_DEPTH 64
#define JTAG_UART_WRITE_THRESHOLD 8
* nios_sysid configuration
#define ALT_MODULE_CLASS_nios_sysid altera_avalon_sysid_qsys
#define NIOS_SYSID_BASE 0x30000
#define NIOS_SYSID_ID 6512
#define NIOS_SYSID_IRQ -1
#define NIOS_SYSID_IRQ_INTERRUPT_CONTROLLER_ID -1
#define NIOS_SYSID_NAME "/dev/nios_sysid"
#define NIOS_SYSID_SPAN 8
#define NIOS_SYSID_TIMESTAMP 1748332863
#define NIOS_SYSID_TYPE "altera_avalon_sysid_qsys"
* onchip_memory2 configuration
#define ALT_MODULE_CLASS_onchip_memory2 altera_avalon_onchip_memory2
#define ONCHIP_MEMORY2_ALLOW_IN_SYSTEM_MEMORY_CONTENT_EDITOR 0
#define ONCHIP_MEMORY2_ALLOW_MRAM_SIM_CONTENTS_ONLY_FILE 0
#define ONCHIP_MEMORY2_BASE 0x0
#define ONCHIP_MEMORY2_CONTENTS_INFO ""
#define ONCHIP_MEMORY2_DUAL_PORT 0
#define ONCHIP_MEMORY2_GUI_RAM_BLOCK_TYPE "AUTO"
#define ONCHIP_MEMORY2_INIT_CONTENTS_FILE "SOC_uart_onchip_memory2"
#define ONCHIP_MEMORY2_INIT_MEM_CONTENT 1
#define ONCHIP_MEMORY2_INSTANCE_ID "NONE"
#define ONCHIP_MEMORY2_IRQ -1
#define ONCHIP_MEMORY2_IRQ_INTERRUPT_CONTROLLER_ID -1
#define ONCHIP_MEMORY2_NAME "/dev/onchip_memory2"
#define ONCHIP_MEMORY2_NON_DEFAULT_INIT_FILE_ENABLED 0
#define ONCHIP_MEMORY2_RAM_BLOCK_TYPE "AUTO"
#define ONCHIP_MEMORY2_READ_DURING_WRITE_MODE "DONT_CARE"
#define ONCHIP_MEMORY2_SINGLE_CLOCK_OP 0
#define ONCHIP_MEMORY2_SIZE_MULTIPLE 1
#define ONCHIP_MEMORY2_SIZE_VALUE 131072
#define ONCHIP_MEMORY2_SPAN 131072
#define ONCHIP_MEMORY2_TYPE "altera_avalon_onchip_memory2"
#define ONCHIP_MEMORY2_WRITABLE 1
#endif /* __SYSTEM_H_ */
Can anyone help me resolve this issue .
Girisha_Dengi
Hello @Fpga_Egr_2025 ,
Please refer to this reference guide to add environment PATH variables.
https://www.intel.com/content/www/us/en/docs/programmable/743810/25-1/manual-system-path-variable-setup.html
Thank you.
Girisha Dengi
Girisha_Dengi
We are working on this solution, we will get back to as soon as possible.
Thank you.
Girisha Dengi
tazzo2
Do you have YOUR_PATH/altera/YOUR_VERSION/niosv/bin on your path? Seems can't call the tool niosv-stack-report
Girisha_Dengi
Hello @Fpga_Egr_2025 , @tazzo2 ,
Can you please try exporting the PATH variable and try once.
Thank you.
Girisha Dengi
Fpga_Egr_2025
what do you mean exporting the path variable ? how to do it
Fpga_Egr_2025
no i dont see any reference to path .
see below my system variable path ;
Fpga_Egr_2025
Girisha_Dengi
Please make sure that NIOS-V BSP or NIOS-V APP absolute path is in the environment variable PATH.
Thank you.
Girisha Dengi
Girisha_Dengi
Thank you.
Girisha Dengi
BoonBengT_Altera
Hi Fpga_Egr_2025,
Seems that there is a solution marked for your doubts. Hence would assume that your clarification has been answered, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
Fpga_Egr_2025
Hi , i was able to compile my design for the NiosV targeting CycloneIVE FPGA on DE2-115 board p/n : EP4CE115F29C7.
But now the JTAG debugging is not working, i searched the forums for that issue and it seems that clock speed has to be double of what system clock is i.e 50Mhz .
See screen shot attached.
SueC_Altera
Hi Fpga_Egr_2025,
Since this thread is marked as solved, please start a new thread with your new question.
Sue
