12748 Discussions
Assembly language w/o syslib
Hello!
Does anyone know how to create an assembly project without a syslib (in Eclipse, Nios II 5.0)? Since I use assembly, I have no need for a syslib.
Any help on how to compile assembly programs using the command line tools would also be much appreciated.
Thank you!
Gustaf
Hi Gustaf,
Take a look at the u-boot sources ... you can strip out everything and
simply use cpu/nios2/start.S and one of the Nios-II linker scripts as
a starting point.
You can obtain the sources from:
http://www.sourceforge.net/projects/u-boot (http://www.sourceforge.net/projects/u-boot) (official sources)
http://www.psyent.com/download (http://www.psyent.com/download) (Nios-only sources)
--Scott
