12742 Discussions
Avalon-MM-Slave address alignment
Contributeur émérite II
2 312 Visites
Hi All
I have aquestion regarding the address alignment of a an-MM slave.
My MM-Save has an avs_readdata and avs_writedata port each 512 bit wide.
Now I'm trying to write the custom pripheral driver for the NIOSII.
There I have to asign the correct address for read and write data but which comes first?
IOWR(base,0,data) IORD(base,513)
or vice versa?
Thank you for your answer!
Ben
0 Compliments
10 Réponses
1 322 Visites
Since the Nios can only do 32bit Avalon master cycles, you really don't want a 512bit wide slave.
You'll only get a bus width adapter that will assert the revelant byte enables for the address.
It is probably much better to write a 32bit slave.
I'm not sure what your problem with IORD() and IOWR() is - they are just wrappers that generate ldio and stio instructions.
As such their definitions aren't entirely useful.
Most device driver writers use C structures to map device registers, it is much less error prone than using integer offsets.
0 Compliments
1 322 Visites
Hi dsl
You're right, I now changed my Avalon MM slave Custom peripheral to us it with burst transfer.
However, I don't know how the _regs.h file needs to look.
For example, how to I write my 32bit width data over the IOWR() makro on the right position of my 512bit wide slave avr_writedata?
Do I need to set the bytenable or address bits? But how?
Thank you for your help
0 Compliments
1 322 Visites
IIRC the Nios won't generate burst transfers either (except maybe for cache line transfers).
So qsys will probably have added a burst adapter!
Personally I'd just define the correct values and ignore the Altera definitions - they just confuse things.
qsys will show a base address for your slave of (say) 0x123000, fix this rather than letting qsys assign the addresses.
In your header file:
#define MY_SLAVE_BASE 0x123000 struct { volatile unsigned int reg_0; .... } my_device registers; extern struct my_device *my_device;
In your source, and assuming you aren't using the MMU:
struct my_device *my_device = (void *)(0x80000000 | MY_SLAVE_BASE);
Then you can access my_device->reg_0 the same as any other variable.
The fabric will convert the low address bits into byte enables for you.
But note that the nios always does 32bit reads, char/short writes will assert the expected byte enables.
0 Compliments
1 322 Visites
If I declare my struct like you stated above and I try to write to reg_0 with
<CODE> my_device->reg_0 = 1;<\CODE>
my NIOS stops working.
However, if I check the address in debug mode of my_device it's the right one.
0 Compliments
1 322 Visites
Hi dsl
I was following the thread with great interest since I'm struggeling with something very similar. Thanks for the enlightenment!
--- Quote Start ---
--- Quote End ---
If this is the case, how can I force it to make the burstcount as big as the number of symbols to be read, in order to
prevent having the burst divided into a bunch of smaller ones?
I'm trying to transfer a 512 Bit package using your mentioned cache-method.
Thanks, Markus.
0 Compliments
1 322 Visites
It is a long time since I've looked at the options.
ISTR there being one to request the cache do bursts.
But it won't generate bursts longer than a cache line.
An alternate approach is to dual port an M9K block as tightly coupled data memory.
That will give the nios the same access times as a data cache hit.
You need to make sure the m9K block is set for OLD_DATA (which implies single clock mode).
0 Compliments
1 322 Visites
thanks for your answer!
--- Quote Start ---
--- Quote End ---
The cache line is defined as 32, but the Nios refuses to make bursts longer than 8. I'd be perfectly fine with a 32-wide burst. This applies to both read and write bursts. :(
0 Compliments
1 322 Visites
Isn't a burst of 8 transfering 32 bytes?
0 Compliments
1 322 Visites
Both avs_readdata and avs_writedata are 32 Bit wide, so in order to have my 512 Bit package delivered, a burst of 16 is needed (whereas a burst of 8 is only half the rent). Please correct me if I'm wrong..
0 Compliments
1 322 Visites
--- Quote Start ---
--- Quote End ---
now I see your point, sorry! Your're right of course. But I need to transfer 64Byte.
0 Compliments
Répondre
