12748 Discussions
Best / Simplest OS for TCP/IP
Hi Folks,
What OS would people recommend a newbi implement on his Nios-II system, so that he can run TCP/IP, UDP, Ethernet etc.
I am looking for an OS with the most support / devkit / Forum experiance.
uCLinux seems popular, but I have no experiance of implementing an OS on Nios, so good documentation, tutorials and reference examples are a key concern.
TTFN.
DJE
--- Quote Start ---
originally posted by devans@Oct 31 2006, 09:33 PM
hi folks,
what os would people recommend a newbi implement on his nios-ii system, so that he can run tcp/ip, udp, ethernet etc.
i am looking for an os with the most support / devkit / forum experiance.
uclinux seems popular, but i have no experiance of implementing an os on nios, so good documentation, tutorials and reference examples are a key concern.
ttfn.
dje
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19048)
--- quote end ---
--- Quote End ---
Sure, you should try uClinux. It is not difficult.
Please follow the uClinux guide on the Nios Wiki, and try out the prebuild image first.
Then setup a Linux PC, install the binary toolchains and uClinux-dist.
You can find with google for documentation, tutorials and reference examples.
