Bug in NIOS2 GCC ?
Could this be a bug in the NIOS2-GCC ?
char testsub(void) {  return __builtin_ldbio (0x1000); }
Generates the following Assembly code (Using -O2 and -fomit-frame-pointer):
movi r3, 4096 ldhio r2, 0(r3) slli r2, r2, 24 srai r2, r2, 24 ret
Why doesn't it just generate a ldbio r2, 0(r3)
I also found the following Code in the (Nios Homedir)/bin/nios2-gnutools/src/gcc/gcc/config/nios2/nios2.md File (available only if GCC Sources are installed) :
(define_insn "ldbio"   UNSPEC_LDBIO))   (use (match_operand:SI 1 "memory_operand" "m"))]  ""  "ldhio\t%0, %1"  )
Does anybody know why GCC translates every __builtin_ldbio into a ldhio?
Hi Sgan,
Thank you very much for finding this issue in the compiler. You are correct that there is a bug here, __builtin_ldbio() should be translating to a ldbio instruction, not a ldhio. This issue will be fixed for the next release of the compiler. If this is causing you a particular issue, I recommend either using __builtin_ldbuio() and sign extending it, or using extended assembly statements.
That said, there is a related conversation elsewhere on the forum that you may be interested in.
http://www.niosforum.com/forum/index.php?a...ct=st&f=2&t=435 (http://www.niosforum.com/forum/index.php?act=st&f=2&t=435
This discusses some of the other issues that you point out here, as even if this bug did not exist, the generated assembly would be:
movi r3, 4096 ldbio r2, 0(r3) slli r2, r2, 24 srai r2, r2, 24 ret
in this case as __builtin_ldXio returns ints.
Jonah
Well, the Subroutine testfunc above at least returns the correct result, because of the shifts... BUT look at this:
long testsub(void) {  return __builtin_ldbio (0x1000); }
When you compile this code, you can be sure that you get wrong results... the generated assembly code looks like this:
movhi r3, 4096 ldhio r2, 0(r3) ret
With this code, you can be sure you get wrong results...
Simon
Hi Sgan,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
With this code, you can be sure you get wrong results...[/b]
--- Quote End ---
You are correct. Which is why I recommend not using the defective builtin.
--- Quote Start ---
Thank you very much for finding this issue in the compiler. You are correct that there is a bug here, __builtin_ldbio() should be translating to a ldbio instruction, not a ldhio. This issue will be fixed for the next release of the compiler. If this is causing you a particular issue, I recommend either using __builtin_ldbuio() and sign extending it, or using extended assembly statements.[/b]
--- Quote End ---
Let me elaborate on the above. What I recommend your code look like is this:
int testsub1(void) {  char x = __builtin_ldbuio ((void *)0x1000);  return (int)x; // sign extend x }
Or using asm statements:
int testsub2(void) {  int x;  asm ("ldbio %, 0(%)" : "=r" (x) : "r" (0x1000));  return x; }
Jonah,
Just wanted to say thanks! I used your asm example in my legacy NiosII port just this hour with great results!
This may be a topic for another thread, but is there any way to read one and only one byte from an 8 bit peripheral? I did the trick of ignoring the bottom 2 address bits to read one and only one address, but still issues 4 read pulses. Not always good with an 8 bit fifo. LDWIO is smart enough to grab all 4 fifo pops into a single long word, but there aren&#39;t always 4 bytes in the fifo.
Ken
