Bug in SOPC?
Why IDT71V416 IP generate 32bit DataBus?Ignore it or I miss something.
My quartus and nios 's version is 5.1
In the SOPC ,I chose the SRAM IP IDT71V416 .The SOPC generate 32bits databus. While the IDT71V416 is 16 bits.
Why????
I confused........ Bug in SOPC or need 2 IDT71V416,But I need only one.
--- Quote Start ---
originally posted by tommycp@Aug 25 2006, 10:26 AM
why idt71v416 ip generate 32bit databus?ignore it or i miss something.
my quartus and nios 's version is 5.1
in the sopc ,i chose the sram ip idt71v416 .the sopc generate 32bits databus.  while the idt71v416 is 16 bits.
why????
i confused........                bug in sopc or need 2 idt71v416,but i need only one.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17821)
--- quote end ---
--- Quote End ---
Altera&#39;s develop board has daul IDT71V416 to combin a 32bit data bus.
So the sram core has a 32 bit data bus.
--- Quote Start ---
my quartus and nios &#39;s version is 5.1
why????
--- quote end ---
--- Quote End ---
Hi TommyCP,
a maybe possible solution for your problem in the "IP download folder"
Regards Frank
hi franky,
Thanks you ,and Could you show me how to get the IP,I can&#39;t find it.or is there some other way to solve this problem,such as ignore the data[16..31]or ......
Tommy
TO_BE_DONE
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Fischer,
Thank you help me again.
Does you just change the Pins generated by IP , without the IP inside.
I have seen the sch(\niosII\documents\nios_cyclone_1c20),which have two IDT71V416.So I wonder whether the IP work if I change the Pins (SOPC generate as you show)or I don&#39;t connect the IDT71V416 properly as the example show.
I thought the IP have its specific connection rules outside and it won&#39;t work if hardware connection goes wrong or not properly.
Thanks again.
Tommy.
Anyone help me!
use component editor:
you create a new component,
(interface description to an external component, not an IP),
you get new signals in your top schematic to connect your SRAM,
you have to connect your SRAM to work properly).
HDL Files : no hdl files
Signals Tab:
Name Interface Signal Type Width Direction
address avalon_tristate_slave_0 address 18 input
data avalon_tristate_slave_0 data 16 bidir
cs_n avalon_tristate_slave_0 chipselect_n 1 input
wr_n avalon_tristate_slave_0 write_n 1 input
rd_n avalon_tristate_slave_0 read_n 1 input
be_n avalon_tristate_slave_0 byteenable_n 2 input
clk avalon_tristate_slave_0 clk 1 input
Interfaces Tab:
Type: avalon_tristate_slave
Slave addressing: Memory (use dynamic bus sizing)
Minimum Arbitration Shares: 1
Can receive stderr/stdout: No
Avalon Tristate Slave Timing:
Setup: 1 , Read Wait: 1 , Write Wait: 1 , Hold: 1 , Units: cycles
Read Latency: 0
SW FIlesw : no files
Component Wizard:
Component name: SRAM_512KBx16
Component Version: 1.01
Conponent Group: Memory
After generation you will get new signals in the top cpu symbol:
cs_n_to_the_sram_512kbx16_0
maybe you get also
write_n_to_the_sram_512kbx16_0
read_n_to_the_sram_512kbx16_0
then connect
cs_n_to_the_sram_512kbx16_0 --> RAM: \CS
write_n_to_the_sram_512kbx16_0 --> RAM:\WE
read_n_to_the_sram_512kbx16_0 --> RAM:\OE
tristate_bridge_0_byteenablen[1] --> RAM:\BHE
tristate_bridge_0_byteenablen[0] --> RAM:\BLE
tristate_bridge_0_address[18..01] --> RAM: A[17..0] (two bytes)
tristate_bridge_0_data[15..0] --> RAM:D[15..0]
(you can share the write and read signals with the tristate_bridge_signals:
tri_state_bridge_0_writen and tri_state_bridge_0_readn,
by manually changing the ptf file (reinsert component in SOPC!)
or using additional logic in top schematic)
Thank you ,I will try.
Dear Fischer,
I met the same problem (My board only has 256kx16 sram)
I built the the component as you said.
But when I run NIOS II IDE(6.0) to build a project.
I can&#39;t find the sram.dat file for simulator use.
But when I use the Memory-> IDT71v416 SRAM, NIOS II IDE will generate
sram.dat for sumulator.
(I had set the program code to sram)
Why ?! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
thanks for yor help
sorry, don&#39;t know how to do this,
perhaps try the 16 bit SRAM component from download section,
http://forum.niosforum.com/forum/index.php...=st&f=15&t=4645 (http://forum.niosforum.com/forum/index.php?act=st&f=15&t=4645)
Great!
I ported it on my board and it work fine
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
