Build error in eclipse
/edit:
!!PROBLEM SOLVED!!
Admin may delete this....
Hi there,
i´m working with Quartus5.0, Nios2 5.0 eval & Nios2IDE 5.0.
While first running these apps i want to execute a simple "HelloWorld" as given in the examples. I opened the Stratix1S10-small in Quartus, run the SOPC-Builder, generated all and opened Nios2IDE. Here i opened this given helloworld-project and tried to build it, what resumes to following:
**** Incremental build of configuration Debug for project hello_world_0 **** make -s all Creating generated_app.mk... Creating generated_all.mk... C:/altera/quartus50/bin/jre/bin/java.exe: not found make: *** Error 1 Build completed
This specified java.exe is at this place.
Please can anybody tell me what went wrong? I think i did everything right... Are these slashes wrong(instead of backslashes)? Do i have to install java sdk?
I´m thankful for any help!
How did you solve it?
I&#39;m stuck as well. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Hm,
not that professional solution at all...
i reinstalled my PC, now i have winXP instead of win2k.
That helps?
