C++ & ISR
Dear all,
I develop my project with C++ language.
But I encounter a problem: how to register a ISR?
For example: I define a UART class
class UART
//Internal Data
protected:
const alt_u32 UART_BASE_ADDRESS;
const alt_u32 UART_IRQ_NUMBER;
alt_u8 bUARTReceiveData;
bool bReceiveNewData;
public:
UART(alt_u32 BaseAddress, alt_u32 IRQNumber):UART_BASE_ADDRESS(BaseAddress),UART_IRQ_NUMBER(IRQNumber)
alt_irq_register(UART_IRQ_NUMBER, this, UartIsr);
~UART() {;}
void UartIsr(void* pClass, alt_u32 id)
bool IsReceiveNewData(void)
return bReceiveNewData;
alt_u8 GetData(void)
return bUARTReceiveData;
But the compiler report that:
error: argument of type `void (UART:: )(void*, alt_u32)' does not match `void (*)(void*, alt_u32)'
I also try:
alt_irq_register(UART_IRQ_NUMBER, this, (void(*)(void*, alt_u32))UartIsr);
But the error still occurred.
Anybody help?
David
I usually use a private static member function in this case, static is necessary, the visibility does not matter. Inside the function you can reinterpret_cast the void pointer to a pointer to your object (assuming you passed 'this' when the ISR was registered).
Thanks for your reply. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
I&#39;ll complete the answer(I got it from Scott McNutt), hope it will be useful for someone who encounter the same problem.
Make the UartIsr() operation class static. E.g.:
static void UartIsr(void* pClass, alt_u32 id);
Remember, the &#39;this&#39; pointer is implicitly passed to non-static member functions -- so non-static member functions can never match a &#39;C&#39; language prototype.
As long as UartIsr is a class member, it can always invoke other member functions regardless of their
visibility:
class UART {
private:
void doISR (alt_u32 id);
protected:
static void UartIsr (void *pClass, alt_u32 id)
UART *uart = (UART *)pClass;
uart->doISR (id);
// ... and other calls as needed ...
// ... and so on.
Thanks Scott McNutt again,
David
