C++ classes...
Hey Guys,
is it possible to do object oriented programming in NIOSII?
when I define a simple class in a .h or .hpp file, I get syntax
errors all over the place....
I even get errors for using the word "class"...
can someone please provide some insight into whether it is
even possible to program C++ in NIOSII?
thanks,
Aydin.
I have not had any problems. I just rename the file created by the new application wizard from a .c to a .cpp file (hello_world.c or whatever) and it works fine.
That is not the problem... I am having trouble declaring my own classes...
I want to be able to declare a really simple class...
however, in order to declare a class, I need to include iostream
and this I cannot do properly....
if there is anyone out there that has been able to run a very simple
c++ program, please please explain how you can include iostream...# include <iostream>
does not work...
thanks,
aydin_y_mirzaee@yahoo.com
--- Quote Start ---
originally posted by aym35@Nov 15 2005, 04:36 PM
hey guys,
is it possible to do object oriented programming in niosii?
when i define a simple class in a .h or .hpp file, i get syntax
i even get errors for using the word "class"...
even possible to program c++ in niosii?
thanks,
aydin.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11002)
--- quote end ---
--- Quote End ---
I noticed the compiler behaves different if the file extention is ".c" instead of ".cpp".
I had trouble wheni included a header containing cpp in a normal c file.
Otherwise cpp works fine.
Karsten
Similarly, the compiler will treat ".c" and ".C" differently.
-Joel-
Karsten
