C example under uClinux
Hallo
I want to write a C program. This C program should use a led on my NIOS II Evaluation Kit, Cyclone Edition. I think i can use the command outl but i believe i must use the include header asm/io.
My first question.
Is that correct?
But i have not this header. So what can i do. Have anyone an idea? Have anyone this header?
you can copy & paste the routine from asm/io
#define inl(addr)
unsigned int __res;
__asm__ __volatile__(
"ldwio %0, 0(%1)"
: "=r"(__res)
: "r" (addr));
__res;
# define inb(addr)
unsigned int __res;
"ldbio %0, 0(%1)"
: "=r"(__res)
: "r" (addr));
__res;
# define outl(b,addr)
"stwio %0, 0(%1)"
: : "r"(http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif , "r" (addr));
# define outw(b,addr)
"sthio %0, 0(%1)"
# define outb(b,addr)
"stbio %0, 0(%1)"
