interupt disabled in ISR
In the Nios II Software developer's handbook:
"the HAL system library disables interupts when it dispatches an ISR".
I've examine the file alt_irq_entry.S and alt_irq_handler.c but no presence of interupts disabling.
Could anybody tell me where are disabled interupts?
thank u in advance.
When an exception is generated, the processor performs the following
steps automatically:
■ Copies the contents of the status register (ctl0) to the estatus
register (ctl1), saving the pre-exception status of the processor
■ Clears the PIE bit of the status register, disabling further hardware
interrupts
■ Stores the address of the instruction after the exception to the ea
register (r29), providing the return address for the exception
handler to return to
■ Vectors to the exception address
thank u for the answer David_Cai.
This is the code of alt_irq_entry.S:
* This is the interrupt exception entry point code, which saves all the
* registers and calls the interrupt handler. It should be pulled in using
* a .globl from alt_irq_register.c. This scheme is used so that if an
* interrupt is never registered, then this code will not appear in the
* generated executable, thereby improving code footprint.
* Explicitly allow the use of r1 (the assembler temporary register)
* within this code. This register is normally reserved for the use of
* the compiler.
.set noat
* Pull in the exception handler register save code.
.globl alt_exception
.globl alt_irq_entry
.section .exceptions.entry.label, "xa"
alt_irq_entry:
* Section .exceptions.entry is in alt_exception_entry.S
* This saves all the caller saved registers and reads estatus into r5
.section .exceptions.irqtest, "xa"
# ifdef ALT_CI_EXCEPTION_VECTOR_N
* Use the exception vector custom instruction if present to accelerate
* this code.
* If the exception vector custom instruction returns a negative
* value, there are no interrupts active (estatus.pie is 0
* or ipending is 0) so assume it is a software exception.
custom ALT_CI_EXCEPTION_VECTOR_N, et, r0, r0
blt et, r0, .Lnot_irq# else
* Test to see if the exception was a software exception or caused
* by an external interrupt, and vector accordingly.
rdctl r4, ipending
andi r2, r5, 1
beq r2, zero, .Lnot_irq
beq r4, zero, .Lnot_irq# endif /* ALT_CI_EXCEPTION_VECTOR_N */
.section .exceptions.irqhandler, "xa"
* Now that all necessary registers have been preserved, call
* alt_irq_handler() to process the interrupts.
call alt_irq_handler
.section .exceptions.irqreturn, "xa"
br .Lexception_exit
.section .exceptions.notirq.label, "xa"
.Lnot_irq:
* Section .exceptions.exit is in alt_exception_entry.S
* This restores all the caller saved registers
.section .exceptions.exit.label
.Lexception_exit:
Which are the instruction that save registers and clears PIE bit?
Probably I miss something.
Thank u
--- Quote Start ---
originally posted by soin@Sep 13 2006, 02:21 AM
which are the instruction that save registers and clears pie bit?
probably i miss something.
thank u
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18247)
--- quote end ---
--- Quote End ---
As David Cai wrote this is automatically done by the processor, not the software. If you want nested interrupts you have to explicitly re-enable interrupts in your ISR.
ok, perfect. I didn&#39;t understood clearly that.
thank u all
and just to be crystal clear, presumably all that needs to be done is something like the following:
#include <io.h># include <system.h># include "sys/alt_irq.h" // ---------------------------------------------------------------------------- alt_irq_context IRQ_ALLOW_ESSENTIAL_START (alt_u32 id,  alt_u32* pActive) {  alt_irq_context Ctrl0;  alt_u32 irq_mask;   //mask out own IRQ and all others having lower priority level    irq_mask = ~(0x0FFFFFFFF << id); // alternatively, mask out self and IRQs 32-29, 28-26    irq_mask = (~(1 << id)) & 0x01FFFFFFF;    *pActive = alt_irq_active;    alt_irq_active &= irq_mask;    NIOS2_WRITE_IENABLE (alt_irq_active); /*  alternatively......  alt_irq_disable (id);                    //Prevent re-entry  alt_irq_disable (<a lower priority interrupt that can wait>);  alt_irq_disable (<another lower priority interrupt that can wait>);  alt_irq_disable (<yet another lower priority interrupt that can wait>); */    NIOS2_READ_STATUS (Ctrl0);    Ctrl0 |= NIOS2_STATUS_PIE_MSK;    NIOS2_WRITE_STATUS (Ctrl0);    return (Ctrl0); } // ---------------------------------------------------------------------------- void IRQ_ALLOW_ESSENTIAL_FINISH (alt_irq_context Ctrl0,  alt_u32 id,  alt_u32 Active) {    Ctrl0 &= ~NIOS2_STATUS_PIE_MSK;    NIOS2_WRITE_STATUS (Ctrl0); /*  alt_irq_enable (<yet another lower priority interrupt that can wait>);  alt_irq_enable (<another lower priority interrupt that can wait>);  alt_irq_enable (<a lower priority interrupt that can wait>);  alt_irq_enable (id); */    alt_irq_active = Active;    NIOS2_WRITE_IENABLE (Active); } // ---------------------------------------------------------------------------- static void MyInterruptibleISR (void* context, alt_u32 id) {  alt_irq_context Ctrl0;  alt_u32 Active; <time-critical section, e.g. reading registers>  Ctrl0 = IRQ_ALLOW_ESSENTIAL_START (id, &Active); <non-time-critical section, e.g. stuffing in buffers>  IRQ_ALLOW_ESSENTIAL_FINISH (Ctrl0, id, Active); } // ----------------------------------------------------------------------------
