CF speed is too slow?
Hello.
I'm now trying to use CF with nios2 dev kit(Stratix2).
But the speed of CF is very slow.
I tried this code.
(VFAT format is used.)
  FILE *fp;   int c;   if ((fp = fopen("/mnt/ide0/test.txt", "r")) == NULL) {        return 0;   }   while ((c = getc(fp)) != EOF){     led->np_piodata = c;  // Blink LED   }
When I use 220kByte test.txt,
it took 1sec for complete this loop.
I need this speed at lease 15MByte/sec.
Is it possible to improve it?
If it's possible, how can I do it?
Thank you.
Please check the PTF file, for CFI.
The read/write wait timing is too slow.
You should change it to mode2 (about 200ns) or mode4.
SLAVE ide
# The timing parameters below ensure proper operation with "Mode 0"
# Compact Flash devices (the slowest speed), in True IDE mode. If
# a different mode is used, these timing settings may be adjuste for
# higher performance.
SYSTEM_BUILDER_INFO
Bus_Type = "avalon";
Address_Alignment = "native";
Address_Width = "4";
Data_Width = "16";
Has_IRQ = "1";
Read_Wait_States = "530ns";
Write_Wait_States = "500ns";
Setup_Time = "70ns";
Hold_Time = "30ns";
--- Quote Start ---
originally posted by m_isshiki@Nov 11 2005, 10:52 AM
hello.
i'm now trying to use cf with nios2 dev kit(stratix2).
but the speed of cf is very slow.
i tried this code.
(vfat format is used.)
  file *fp;   int c;   if ((fp = fopen("/mnt/ide0/test.txt", "r")) == null) {        return 0;   }   while ((c = getc(fp)) != eof){     led->np_piodata = c;  // blink led   }
when i use 220kbyte test.txt,
i need this speed at lease 15mbyte/sec.
is it possible to improve it?
if it's possible, how can i do it?
thank you.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10918)</div>
--- Quote End ---
