I have a spansion S29GL064N CFI flash that connected to a cyclone IV FPGA and I use Quartus II V11.1. when I use nios2-flash-programmer command in the command shell, CFI flash table found. also, nios II flash programmer is used to program it and results was true. I think all things are true, but FPGA can not be configured by CFI Flash(or config done pin is '1'). how can i fix this problem? notice that in the sopc builder reset vector is set to cfi_flash. regards,链接已复制
7 回复数
If you were able to verify the content of the flash then the problem is in your pof file. Make sure your FPGA configuration and software work properly when downloaded directly with JTAG. Once that is verified, see the Altera instructions on creating a pof file and try again.
You cannot configure a Cyclone IV FPGA from CFI memory without an external controller - such as a CPLD or micro. Do you have either of those? A Cyclone IV FPGA cannot control a CFI memory device directly for the purposes of configuration.
Refer to the "PS Configuration" section, page 8-32, of the configuration and remote system upgrades in cyclone iv devices (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-51008.pdf) for details. Cheers, AlexHi,
Thanks. Can i use cfi flash in the active parallel mode , if i connect it to dedicated active parallel fpga pins similar to "AP Configuration" sectiON,of the Configuration and Remote System Upgrades in Cyclone IV Devices. REGARDS
