12748 Discussions
CFI FLASH access from Nios IDE
Good afternoon.
Unfortunatelly, i didn't find the solving of the problem with CFI Flash, so i decided to create a new thread.
I have Cycolne III Dev Kit and flash on the board and want to make access to flash through the CFI.
i have added the CFI Flash and Tri-state Bridge to my project. then made pins in the quartus and try make access to the flash.
At last i could get the CFI table from the Nios Command Shell through the nios2-flash-programmer and today i have succefully wrote data to the flash and read it from flash.
But i can't do the same in the Nios II IDE. The result of function alt_flash_open_dev(CFI_FLASH_NAME); is zero - so the device doesn't open.
The options in system library included all wrivers and the CFI i thnk so too...
Are there any ideas why it doesn't work?
I had the same problem 3 weeks ago.
The CFI flash is a 16-bit addressable device. I guess you have it wired up as if it was 8-bit addressable.
Connect bit 1 of the NIOS address to bit 0 of the CFI device in your Verilog
eg
flash_padd[22..0] = nios_mod.address_to_the_cfi_flash[23..1];
flash_padd[23] = clr;
hope that helps ...
Bruce
Thank you very much.
I've already successfully done the cfi flash.
You are right, we should connect Nios [1] to pin flash[0].
Besides we shouldn't mark option "reduced device drivers" or the drivers for the Flash won't be included.
Today i tried to start the nios software from the CFI Flash and it works.
if anybody have questions about the CFI Flash with Nios I'll try to answer it =)
Unfortunatelly i have another problem: i can't get access to the flash from nios ide in the example of simple socket server (SSS), but i can see the cfi table from command shell of nios ide. I didn't check the small с library or reduced drivers in system library.
But when i start the example of hello world - i can access flash from nios ide but a have the same settings of system library as for the SSS =(
Are there any ideas about this case?
Hello to everybody.
I made my flash workable, but now I have a question.
I have a special board with Cyclone III, not dev kit.
There is no Max II.
So I want to program my flash with Nios software to store there my cpu code.
How can i programm it?
There is a parallel flash loader, but it can load only pof files (sof i can convert to pof). And what about the *.flash type?
Maybe there is a converter such as sof2flash, but flash2sof?
