hi, everyone
i designed a nios ii board with SRAM, SDRAM, FLASH, EPCS, UART etc, i can program my software to FLASH and EPCS through NIOS II IDE, the board works correct, it sent message through UART to my hyper-terminal, but, when i try use HAL to access UART and CFI FLASH, it does not work. it can not open the device. i use debug to trace the program, i found that in alt_device_list just has ONE device "/dev/EPCS",no UART and FLASH in the list. what's wrong? who can help me ?Link Copied
PS: I do not check "reduced device drivers"
