linux:make error
i fellow http://www.nioswiki.com/linux (http://www.nioswiki.com/linux
when i input make command,it came to a error as bellow;
make[2]: Entering directory `/mywork/nios2-linux/uClinux-dist/vendors/Altera/nios2'
set -e;
t=`nios2-wrs-linux-gnu-gcc -mhw-mul -mno-hw-mulx -print-file-name=libc.a`;
t=`dirname $t`/../..;
for i in $t/lib/*so*; do
i=`readlink -f "$i"`;
soname=`nios2-wrs-linux-gnu-readelf -d "$i" | sed -n '/(SONAME)/s:.*[[]\(.*\)[]].*:\1:p'`;
if [ ! -f "/mywork/nios2-linux/uClinux-dist/romfs/lib/$soname" ] ; then
romfs-inst.sh -d -p 755 $i /lib/$soname;
fi;
done;
if [ "y" = "y" ] ; then
/mywork/nios2-linux/uClinux-dist/vendors/AnalogDevices/trim-libs.sh;
fi;
if type nios2-wrs-linux-gnu-ldconfig >/dev/null 2>&1; then
nios2-wrs-linux-gnu-ldconfig -r /mywork/nios2-linux/uClinux-dist/romfs;
fi
/mywork/nios2-linux/uClinux-dist/vendors/AnalogDevices/trim-libs.sh: line 19: scanelf: command not found
ERROR: you do not have pax-utils installed
make[2]: *** [romfs.shared.libs] 错误 1
make[2]: Leaving directory `/mywork/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make[1]: *** [romfs.post] 错误 2
make[1]: Leaving directory `/mywork/nios2-linux/uClinux-dist/vendors'
why it happenedd,and how can i deal with it??
Install pax-utils :-) Seriously, find out how to install the pax-utils program on your system. Most Linux distros even have a GUI for this, these days.
Cheers,
- slacker
<div class='quotetop'>QUOTE (slacker @ Sep 4 2009, 11:43 AM) <{post_snapback}> (index.php?act=findpost&pid=23750)</div>
--- Quote Start ---
Cheers,
- slacker[/b]
--- Quote End ---
ths,slacker
i have installed paxutils-2.4h,below is how i installed
tar xfz paxutils-2.4h.tar.gz
cd paxutils-2.4h
./configure
make && make check
make install DESTDIR=/usr/src/paxutils-2.4h/.inst
but the ERROR: you do not have pax-utils installed still not removed,
is the paxutils version wrong?? or any other reason??
thanks..
thks,slacker
i have removed the error after installing pax-utils
can you tell me that how did you solve the problem ?
I have the very same problem.
thanks!
--- Quote Start ---
<div class='quotetop'>QUOTE (slacker @ Sep 4 2009, 11:43 AM) <{post_snapback}> (http://index.php?act=findpost&pid=23750)</div>
ths,slacker
cd paxutils-2.4h
./configure
make && make check
thanks..
--- Quote End ---
