CGI problem
Hello:
I am testing a CGI program using C language and Shell under the Nios2 Linux system.
What I want is to implement the "Redirection" function to redirect user's browser to a website:
for exmaple "www.google.com".
My approach is to print the "Location: URL" header to user's browser.
What I did is like this, I wrote a C program that is doing simple I/O access,and contains the last line:
printf("Location: http://www.google.com\n\n"); (http://www.google.com\n\n&quot%3b%29;)
I also wrote a shell scirpt which was:
# !/bin/sh
echo "Location: http://www.google.com" (http://www.google.com")
echo ""
Finally,I put them into the proper place and tried to link them using IE.
Both execution turned out successful(I/O result was correct),but they did't bring me to google!
After the execution,both of them only took me to the previous folder.
(i.e. from http://192.168.1.1/cgi-bin/test.cgi (http://192.168.1.1/cgi-bin/test.cgi) to http://192.168.1.1/cgi-bin/ (http://192.168.1.1/cgi-bin/) )
Can anyone please tell me what's the problem!?
Thank you so much.
Best Regards.
I presume that you're using boa?
Hello clansdown:
Yes,I am using boa.
Two other questions:
(1) What happens if you go to it manually, e.g.
telnet host 80 GET /cgi-bin/test.cgi HTTP/1.1 Host: hostname
(2) What happens if you use some other browser, such as Firefox?
