- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I'm just starting to try to integrate some user logic with a NiosII core. I have read round this
quite a bit, including searching here but still have a few questions. I have the following interfaces at the top of my module that I need the CPU to be able to read and write to.. din : in std_logic_vector(15 downto 0); -- writedata wr : in std_logic; -- write op_enable : in std_logic; -- writedata op_polarity : in std_logic; -- writedata int_en : in std_logic; -- writedata empty_flag : out std_logic; -- readdata empty_intrpt : out std_logic; -- irq buffer_size : out std_logic_vector(9 downto 0) -- readdata I have tried integrating this using the 'Interface to User Logic' Legacy component, defining each interface as above. I have 6 read or write elements, but when SOPC builder created the component it only allocated 4 addresses for the component. Has it lumped ports into the same address? (As an aside, I presume it's more efficient for me to concatenate signal lines internally and provide fewer interface ports allowing the SW to identify the relevant bits). How do I know what's been allocated to which address? I'd like the interrupt to be edge triggered. When adding a PIO port you're given the option to select how the interrupt is raised. How is this defined for user logic? Thanks for any help with this, the documentation covering this doesn't seem clear and consise, and what there is is scattered far and wide (cue someone to post a link to an easily found idiots guide to user logic interfacing). Nial.コピーされたリンク
0 返答(返信)
