12748 Discussions
Can not find file "altera_avalon_timer.h"
Hi Everybody,
I have got the problem when finding the solution to measure performance of C program on NiosII.
Here is the example code that I have followed an example in Nios II handbook:
# include "sys/alt_timestamp.h"
# include "alt_types.h"
int main(void)
int the;
double sinLookup[Thetamax];
double cosLookup[Thetamax];
alt_u32 time1;
alt_u32 time2;
time1 = alt_timestamp();
//Make a sin and cos lookup-table for performance improvement
for(the=0;the<Thetamax;the++)
sinLookup[the] = sin(the*PI/180);
cosLookup[the] = cos(the*PI/180);
time2 = alt_timestamp();
printf ("time in func1 = %u ticks\n",(unsigned int) (time2 - time1));
printf ("Number of ticks per second = %u\n",(unsigned int)alt_timestamp_freq());
}//main(void)
For Hardware, I added an Interval Timer on SOPC Builder.
The problem happened when I compiled this code to run on Nios. There was three errors:
"/cygdrive/c/altera/11.0sp1/nios2eds/components/altera_hal/HAL/inc/sys/alt_timestamp.h:43:33: altera_avalon_timer.h: No such file or directory"
"undefined reference to `alt_timestamp' "
"undefined reference to `alt_timestamp_freq' "
I have checked on directory "/altera/11.0sp1/nios2eds/components/altera_hal/HAL/inc", the file "altera_avalon_timer.h" does not exist.
I am using Quartus v11 sp1, Nios II v11 sp1.
If somebody know what my problem is, could you please show me the solution for this problem ?
Thanks in advance,
Khai.
The file altera_avalon_timer.h exists in the directory of the timer component:
C:\altera\11.0sp1\ip\altera\sopc_builder_ip\altera_avalon_timer\HAL\inc
Not sure why it couldn't find it, maybe there is something wrong with your include directories or your project in the Nios II IDE doesn't know that there is a timer instance in your hardware... maybe you have to re-generate the *.ptf / *.sopc files.
You should add the timer to your timestamp_timer_settings in the BSP/system library:
SysLib/BSP -> Properties -> System Library -> Timestamp Timer
This setting is 'none' by default
