Dear all,
first,i will thank to your help,my computer is xp os ,vmware 5.5,fadora 4,when i install vmware tool use the command vmware-install.pl then emerge the following information,and can't complete vmware tool what is the location of the directory fo C header files that match you running kernal ?[/usr/src/linux/include] help me ,thanks連結已複製
1 回應
<div class='quotetop'>QUOTE </div>
--- Quote Start --- Dear all, first,i will thank to your help,my computer is xp os ,vmware 5.5,fadora 4,when i install vmware tool use the command vmware-install.pl then emerge the following information,and can't complete vmware tool what is the location of the directory fo C header files that match you running kernal ?[/usr/src/linux/include][/b] --- Quote End --- Hi: Maybe you need to install the gcc compiler first!
