why has two compilers
Contributeur émérite II
1 053 Visites
Hi hippo.
in staging_dir , It has nios2-linux-gcc and nios2-linux-uclibc-gcc,Why?
Could you tell me which is the default apps's library?
0 Compliments
1 Répondre
372 Visites
--- Quote Start ---
originally posted by zzh@May 25 2006, 11:08 AM
hi hippo.
in staging_dir , it has nios2-linux-gcc and nios2-linux-uclibc-gcc,why?
could you tell me which is the default apps's library?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15563)
--- quote end ---
--- Quote End ---
nios2-linux-gcc is a symbolic link (similar to short cut in Windows) , pointed to the real nios2-linux-uclibc-gcc.
The default apps library is uClibc&#39;s libc, so you don&#39;t need -lc .
If you use math, you need -lm .
If you use pthread, you need -lpthread .
If you use crypt, you need -lcrypt .
.....etc.
You will need those include headers, too.
The order of librarys is important, the linker will search only one pass by default.
The default include dir search path is staging_dir/include .
The default library search path is staging_dir/lib .
0 Compliments
Répondre
