Can't open ttyS0 !!!
Hi All !
I used 2s60ES and build uclinux for my board . I wrote simple example relate with UART this is my code :
struct termios options;
fd=open("/dev/ttyS0",O_RDWR );
if(fd==-1)
printf("Cannot open ttyS0!!\n");
exit(0);
fcntl(fd,F_SETFL,0);
tcgetattr(fd,&options);
options.c_cflag |=(CLOCAL | CREAD);
then I ran my example it CANNOT OPEN TTYS0 !!!!
thanks for help !
Did you enable nios uart driver in kernel config?
If you already run console or shell on the uart, you can't open it again. use stdin/out instead.
Otherwise, try "cp /etc/motd /dev/ttyS0" .
