Hi All !
I used 2s60ES and build uclinux for my board . I wrote simple example relate with UART this is my code : struct termios options; fd=open("/dev/ttyS0",O_RDWR ); if(fd==-1) { printf("Cannot open ttyS0!!\n"); exit(0); } fcntl(fd,F_SETFL,0); tcgetattr(fd,&options); options.c_cflag |=(CLOCAL | CREAD); ...... ........ then I ran my example it CANNOT OPEN TTYS0 !!!! thanks for help !Link Copied
Did you enable nios uart driver in kernel config?
If you already run console or shell on the uart, you can't open it again. use stdin/out instead. Otherwise, try "cp /etc/motd /dev/ttyS0" .
