12748 Discussions
Code blocked in the ISR routine...
I want to generate a simple Push Button ISR routine...
But my code didn't work...
The interrupt occurs but the program still in the ISR routine...
Here the declaration of the init_button_pio()
    static void init_button_pio()     {         /* Recast the edge_capture pointer to match the         alt_irq_register() function prototype. */         void* edge_capture_ptr = (void*) &edge_capture;         /* Disable button interrupts. */         IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_BASE, 0x0);         /* Reset the edge capture register. */         IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_BASE, 0x1);                  /* Register the ISR. */         alt_irq_register( button_IRQ, edge_capture_ptr, handle_button_interrupts );                /* Enable button interrupts. */         IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_BASE, 0x1);     }
And, here the ISR routine :
    static void handle_button_interrupts(void* context, alt_u32 id)     {         /* cast the context pointer to an integer pointer. */         volatile int* edge_capture_ptr = (volatile int*) context;         /*         * Read the edge capture register on the button PIO.         * Store value.         */         *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(button_BASE);                  /* Write to the edge capture register to reset it. */         IOWR_ALTERA_AVALON_PIO_EDGE_CAP(button_BASE, 0x0);         /* MY CODE*/         IOWR_ALTERA_AVALON_PIO_DATA(leds_BASE, ledCount ++);                           /* reset interrupt capability for the Button PIO. */         IOWR_ALTERA_AVALON_PIO_IRQ_MASK(button_BASE, 0x1);     }
I don't understand why my code is staying in the ISR, I reset the edge capture register...
Thank you for your help.
Hi there,
Is your button input de-bounced? If not it could generate a series of consecutive interrupt requests so that as soon as you leave the ISR it re-enters again. If you run your code, rather than step through it, what happens? I'd guess that it would change the state of your LEDs, but in a somewhat erratic fashion.
If your button inputs are debounced to provide a single clean edge, there should be no problem.
Cheers
