I would like to make an interruption of the DMA via NIOS II. I took the example from the NIOS II software Developper Handbook and added the three alt_irq commands in order to initialise, register and enable my interruption. My interruption is number 6 thus I wrote : alt_u8 buffer[1024]; alt_dma_rxchan rx; /* flag used to indicate the transaction is complete */ volatile int dma_complete = 0; /* function that is called when the transaction completes */ void dma_done (void* handle, void* data) { dma_complete = 1; } int main(void) { alt_irq_init (VGA_BASE); // avec dans system.h :# define VGA_BASE 0x00008200 alt_irq_register (6,NULL, dma_done); alt_irq_enable (6); /* Obtain a handle for the device */ if ((rx = alt_dma_rxchan_open ("/dev/vga")) == NULL) { printf ("Error: failed to open device\n"); exit (1); } else { /* Post the receive request */ if (alt_dma_rxchan_prepare (rx, buffer, 1024, dma_done, NULL) < 0) { printf ("Error: failed to post receive request\n"); exit (1); } /* Wait for the transaction to complete */ while (!dma_complete); printf ("Transaction complete\n"); alt_dma_rxchan_close (rx); } return 0; } Then, I have the following message on the console : "Error: failed to open device". I am a newbie with NIOS II so maybe my mistake is huge. Could someone help me ? Thank you very much, I am lost.Link Copied
