Communication with RS232 UART
I am just trying to see some activity out of the Avalon RS232 UART. I have instrumented my board's TX and RX lines on my 232 device ands am running the simple example below( Took from Software Handbook and then modified for just writes):
I get the error at runtime:
nios2-terminal: can't open uart: Permission denied
Any tips or thoughts?
/* A simple program that recognizes the characters &#39;t&#39; and &#39;v&#39; */# include <stdio.h># include <string.h># include "system.h"
int main()
char* msg = "Detected the character &#39;t&#39;. \n";
FILE* fp;
char prompt = 0;
//fp = fopen ("/dev/uart_1", "r+"); // Open file for reading and writing
fp = fopen ("/dev/uart_1", "w"); // Open file for reading and writing
//print a message to console
//printf(" I am starting UART Test \n ");
fprintf(fp, "Open the UART \n");
//printf(" Should have written to UART .\n");
if(fp)
fprintf(fp, "%s",msg);
fclose(fp);
if(fp)
while(prompt != &#39;v&#39;)
{ // Loop until we receive a &#39;v&#39;.
prompt = getc(fp); // Get a character from the UART
if(prompt == &#39;t&#39;)
{ // print a message if character is &#39;t&#39;.
fwrite(msg, strlen(msg), 1, fp);
fprintf(fp, "Closing the UART file. \n");
fclose (fp);
return 0;
Just an update to this problem. The nios2-terminal problem was due I believe to another session already open, hint I got from Altera. However, the simple HAL file example, where the UART is treated as a character device still does not work. I have double checked my connections,SOPC build, pin files, analyzer settings, trigger,etc, but I do not see any activity on the TX pin of the FPGA when I run my example( borrowed from Altera&#39;s software manual).
Any thoughts on UART RS232 comm?
This turned out to be operator error.
The code example above works fine on a custom board that we are developing. The HAL approach is very clean as opposed to setting up registers for the UART. Also, I am using the Bray terminal that I saw referenced here in the forum, it is much better than Hyperterminal!
http://bray.velenje.cx/avr/terminal/ (http://bray.velenje.cx/avr/terminal/
-Baycool
