CompactFlash support
Hi all, I try to put in operation the CompactFlash in my development kit, but during the compilation of uClinux source I have this errors :
...............................................................................   CC      fs/splice.o   LD      sound/built-in.o   CC      kernel/srcu.o   CC      drivers/ata/libata-core.o   CC      kernel/semaphore.o   CC      fs/sync.o /home/campo/Quartus_Project/nios2-linux_prova/linux-2.6/drivers/ata/libata-core.c: In function `ata_wait_register': /home/campo/Quartus_Project/nios2-linux_prova/linux-2.6/drivers/ata/libata-core.c:6155: error: implicit declaration of function `ioread32' make: *** Error 1 make: *** Error 2 make: *** Error 2 make: *** Waiting for unfinished jobs....   CC      fs/utimes.o   CC      kernel/notifier.o   CC      fs/stack.o   CC      fs/buffer.o   CC      fs/bio.o ............................................................................... make: *** Error 2 make: Leaving directory `/home/campo/Quartus_Project/nios2-linux_prova/linux-2.6' make: *** Error 1
I follow this (http://www.nioswiki.com/operatingsystems/uclinux/compactflash) . Has someone resolved this problem ?
Sorry for my bad english and thanks in advice.
I have exactly the same error, did you manage to fix this problem?
Should update the library libata? (Kernel : 2.6.23-uc)
Hi all,
Here is the error message when compiling :
drivers/ata/libata-core.c: In function `ata_devchk':
drivers/ata/libata-core.c:640: error: implicit declaration of function `iowrite8'
drivers/ata/libata-core.c:649: error: implicit declaration of function `ioread8'
drivers/ata/libata-core.c: In function `ata_sg_setup_one':
drivers/ata/libata-core.c:4329: warning: use of cast expressions as lvalues is deprecated
drivers/ata/libata-core.c:4353: warning: use of cast expressions as lvalues is deprecated
drivers/ata/libata-core.c: In function `ata_sg_setup':
drivers/ata/libata-core.c:4412: warning: use of cast expressions as lvalues is deprecated
drivers/ata/libata-core.c: In function `ata_data_xfer':
drivers/ata/libata-core.c:4490: error: implicit declaration of function `iowrite16_rep'
drivers/ata/libata-core.c:4492: error: implicit declaration of function `ioread16_rep'
drivers/ata/libata-core.c:4501: error: implicit declaration of function `iowrite16'
drivers/ata/libata-core.c:4503: error: implicit declaration of function `ioread16'
drivers/ata/libata-core.c:6816: error: implicit declaration of function `ioread32'
make[4]: *** [drivers/ata/libata-core.o] Erreur 1
make[3]: *** [drivers/ata] Erreur 2
Should defined ioread8, ioread16 ... in asm/io.h?
# define ioread8(X) readb(X)# define ioread16(X) readw(X)
What is the kernel configuration for the compact flash?
I followed the instructions given in nioswiki : http://www.nioswiki.com/operatingsystems/u...ux/compactflash (http://www.nioswiki.com/operatingsystems/uclinux/compactflash
Please pull update. The current kernel is v2.6.30.
- Hippo
