12746 Discussions
Compiing uC-TCP-IP for NiosV
SDe_J
Hi Intel Forums,
I'm trying to build the simple socket server for an Agilex 7 devkit. I've got the NiosV processer and peripherals set up via platform designer and I've built a BSP with includes the 'uC-TCP-IP' libraries. Unfortunately when I try to build the C project in RiscFree, I get this error:
[ 77%] Building C object bsp/CMakeFiles/hal2_bsp.dir/uC-TCP-IP/uC-LIB/lib_math.c.obj
<MY LOCAL PATH>/software/bsp/uC-TCP-IP/uC-DHCPc/OS/uCOS-II/dhcp-c_os.c:166:9: error: unknown type name 'OS_TMR'
166 | static OS_TMR *DHCPc_OS_TmrPtr;
Is there something I need to include to solve this error?
Let me know if there's more information I can provide. If needed I can share the whole project or the qsys file.
Thank you,
Sam
JingyangTeh_Altera
Hi
You would need to edit the BSP settings for the Nios V.
Please follow the steps below:
https://www.intel.com/content/www/us/en/docs/programmable/726952/22-1-21-2-0/configuring-the-bsp.html
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any update on this case?
Are you able to compile the example desing after the BSP configuration?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
