12748 Discussions
Component Editor in QII v4.2sp1
I am trying to use SOPC Builder to generate a new component with one Avalon master and two Avalon slaves. I declared the three interfaces under the corresponding tab (and renamed them), then went back to signals and assigned each one to its own interface. I saved the component and used it fine. But now if I want to edit the component, every time it opens the Component Editor it resets the interfaces to the default avalon_slave_0 name and settings (losing the other two) and all the signals are reassigned to the default slave as well.
As a result, I am forced to go back to manual class.ptf editing in Notepad. Is there anything I can do to properly use the Component Editor (maybe a setting or a patch that I am not aware of) or should I just wait for the new Quartus release?
Thanks and Regards,
C
