12747 Discussions
Configure Kernel menu disappeared!
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
I installed the Nios II 1.0 and embedded linux a while ago. It worked well. Today when I tried again to build a linux kernel project inside of Nios II IDE, I could not find the "Configure Kernel" command from the drop down menu by right-click the created project. Does anyone know why it happened?
hello
for this problem you should reinstall version linux2nios 1.3
--- Quote Start ---
originally posted by olive_zhao@Jan 13 2005, 12:17 AM
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
i installed the nios ii 1.0 and embedded linux a while ago. it worked well. today when i tried again to build a linux kernel project inside of nios ii ide, i could not find the "configure kernel" command from the drop down menu by right-click the created project. does anyone know why it happened?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=3851)
--- quote end ---
--- Quote End ---
You&#39;d better build on Linux PC, follow my guide,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174
Or,
how to run the uClinux in NIOS2 in chinese by Alex.liu.
http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52 (http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52
Post your uClinux questions on the uClinux forum of nios2.
