12745 Discussions
Configure NIOS firmware burning interface
ZhiqiangLiang
I would like to run NIOS II in FPGA. I am now use Cyclone 10 LP 10CL120.
I have a few questions:
1)  how to enable/configure UART burning interface in Quartus Platform Designer?
2) If I don't enable/config UART burning interface, is there any other way to burn firmware to NIOS on FPGA?
3) If I configure RAM and ROM size for NIOS, I don't know what is the maximum size I can set as I don't know what is the remained resource in FPGA?
4) in Platform Designer, if I create a New Component, it is very difficult to config "Signals & Inferfaces" in Compent Editor. For example, what is conduit?  how to config AXI4 Lite Slave interface?
5) if I enable/configure SPI or Ethernet, is the C driver enabled in Eclipse? how to enable the driver?
SueC_Altera
Hi ZhiqiangLiang,
Please start a new thread for a new question.
Sue
ZhiqiangLiang
@JitLoonL_Altera
I get new questions about burning ROM or flash.
in my Cyclone 10 FPGA, I instance NIOS II, RAM(120KB), ROM(80KB), UART, JTAG, but no EPCS Flash controller as which is not supported by Cyclone 10 family.
I am able to program jic file via JTAG and the tool: Quartus-->Tools-->Programmer.
but I can't add elf file to Quartus-->Tools-->Programmer. elf type file is not supported by Programmer which supports 5 types(sof, pof, jam, jbc, ekp, jic).
Eclipse-->NIOS II -->Flash Programmer, I can't program elf as well, because:
1) The tools report error: Target is broken and needs to be reset, however, Quartus-->Tools-->Programmer is able connect and burn jic file to flash.
2) I don't know where the elf is burned through Flash Programmer?
is there any detailed guide that tells me how to burn elf file to ROM that I instance in FPGA?
BoonBengT_Altera
Hi @ZhiqiangLiang,
I believe that your doubts should have been answered and you have also started a new post for the question. Hence with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
If that is not the case, you can always login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
