12612 Discussions
Cyclone 10 GX Development Board
Anu_Jayan
   Hi, I am using Cyclone 10 GX Altera Nios 2 "10CX220YF780E5G" Development board. Can you provide example source code for "Ethernet PHY 88E1111", to build in Eclipse IDE into Nios 2 EDS.
Paveetirra_Srie
Anu_Jayan
Hi Paveetirra_Srie
   I am using Ubuntu version 20.04.5 system & I have installed the Intel Quartus Prime Pro Edition 21.4 (FREE, no license file required) following the below procedure link.
https://www.intel.com/content/www/us/en/software-kit/706104/intel-quartus-prime-pro-edition-design-software-version-21-4-for-linux.html
Also installed the Eclipse IDE into NIOS II EDS from the below procedure link.
https://www.terasic.com.tw/wiki/Getting_Start_Install_Eclipse_IDE_into_Nios_EDS
I have successfully installed both the software's. Then I downloaded the example source code for "Cyclone 10 GX Development Board" from the below link (Kit Collateral zip).
https://www.intel.in/content/www/in/en/products/details/fpga/development-kits/cyclone/10-gx.html
1) Opened Quartus -> Tools -> Nios II software build tools for eclipse
2) After extracting the "Kit Collateral zip" file, I tried to import the example simple socket server path into the "Nios II software build tools for eclipse" for testing the Ethernet port.
   File -> Import -> Existing Projects into Workspace -> Next->  Browsing the path of "simple socket server" -> Finish
3) The Project is created in the Project Explorer window.
3) Now I tried to Build the project named as sss_c10gx_app & sss_c10gx_bsp . But the build failed throwing errors in Problems window.
I have attached the captured error log. Kindly help me to resolve the issue.
AnuJayan
Paveetirra_Srie
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
Anu_Jayan
Thanks for your input on this query. I will get back to you if I have any doubt.
AnuJayan
