12748 Discussions
Cyclone V FPGA-to-HPS Bridges design example bug?
I found what appears to be a bug in the example_design.c file, but didn't see a means to report it directly. So, I'm posting it here.
example_design.c:233
for(int i=0; i<test_set->hardware_instances; i++) { test_set->bg_counters = 0; }
should be
(see https://www.altera.com/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html)
Thanks for notifying the bug, let us check/workaround it.
We will get back to you on this as soon as possible.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
