- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Finally had a chance sit down and play around with DE0-Nano. I am using Quartus/Qsys 11.1 and Nios II 11.1 Software build tools.
I thought as a relatively quick project I would experiment using the opencores I2C master downloaded from alterawiki.com/wiki/I2C_(OpenCores) to interface with the ADXL345 accelerometer and 24LC02B eeprom ICs on the DE0-Nano board. The first problem I hit was with the version of Qsys required by the I2C master (12.0 vs 11.1). I simply used the 'New component' wizard in Qsys to generate the new _hw.tcl file with the following wishbone to avalon bus signal assignments: wb_clk_i --- clk wb_rst_i --- reset wb_adr_i --- address wb_we_i --- write wb_ack_o --- waitrequrest_n wb_dat_i --- writedata wb_dat_o --- readdata wb_stb_i --- chipselect wb_inta_o --- irq scl_pad_io --- export sda_pad_io --- export I then made the following pin assignments scl_pad_io == PIN F2 (output) sda_pad_io == PIN F1 (bi-dir) PIN G5 (G_SENSOR_CS_N) I tied to VCC to ensure the accelerometer is in I2C mode rather than SPI mode. I had a few more niggles after this, specifically getting the driver to be recognised by Nios II IDE. Turns out I had to rename all instances of opencores_I2C to I2C_opencores in the _sw.tcl file. Now I have the following code which is running on the DE0-Nano, which should write 0x55 to the first byte of the eeprom and read back the same byte as a second I2C transaction. The eeprom 7-bit address should be 0x50 (assuming I have found the correct datasheet). The software functions are defined with I2C_opencores available from the link above. //Intialise I2C master controller at 100kHz, 50MHz Cpu clock. I2C_init(I2C0_BASE,ALT_CPU_CPU_FREQ,100000); // Write 0x55 to location 0x0 for I2C device at 0x50 (22LC02B) I2C_start(I2C0_BASE,0x50,0); I2C_write(I2C0_BASE,0x0,0); I2C_write(I2C0_BASE,0x55,1); // Write address that is to be read from I2C_start(I2C0_BASE,0x50,0); I2C_write(I2C0_BASE,0x0,0); // Read from the device I2C_start(I2C0_BASE,0x50,1); data = I2C_read(I2C0_BASE,1); printf("Data: 0x%x \n",data); However I get the following console output if I defined I2C_DEBUG... Initializing I2C at 0x40040b0, with clock speed 0x2faf080 and SCL speed 0xc350 and prescale 0xc7 Start I2C at 0x40040b0, with address 0x50 and r/w 0x0 NOACK Write I2C at 0x40040b0, with data 0x0, with last 0x0 ACK Write I2C at 0x40040b0, with data 0x55, with last 0x1 ACK Start I2C at 0x40040b0, with address 0x50 and r/w 0x0 NOACK Write I2C at 0x40040b0, with data 0x0, with last 0x0 ACK Start I2C at 0x40040b0, with address 0x50 and r/w 0x1 NOACK Read I2C at 0x40040b0, with last 0x1 Data: 0x50dc5a0f What I don't understand is why I am getting an NOACK response from the start transaction, but do get an ACK response from the following write transaction. Without a scope/logic analyser I am a bit stuck as to what could be going wrong. Hope there is someone out there who has had a similar experience to me and will be able to help me out.Link kopiert
3 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there,
I'm working on the adxl345 on DE0-nano board for my university project, and I have the same problems with My nios program in eclipse IDE . I'm using Quartus 11.1 and I will appreciating if you send me the programs. when I run the program It does not even start the transmitting and I suspect my sw.tcl or one other file is corrupted by the changes that I did to those files, Anybody knows how can I run this core into my design?? I'd appreciating if somebody help me. farshid_mfc[at]yahoo.com- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
H there,
I have taken a module from http://www.eewiki.net/display/logic/i2c+master+%28vhdl%29 when integrating to the Avalon bus i have had some issues. This is not wishbone compliant and my plan was to write my own wrapper but with time running out i was an unit testing needed i was wondering if; Altera supply a bus similar to that of the clock crossing bridge? Thanks- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi there,
I have a DE0 Nano as well, and I am using the same versions of Quartus/Qsys and Nios II, but for some reason I dont have any signal at the scl_pad_io or sda_pad_io pins (they are asssigned to pins on the GPIO header). I know it's been a long while since this thread was last active, but if you could help me I would appreciate it a lot :) Cheers, Salman
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
