12745 讨论
DM9000 could supported by uClinux?
名誉分销商 II
1,410 次查看
When make menuconfig, I choose the networking supporting, because my altera board is DE II, it's ethernet is DM9000, so I choose the DM9000 in devrice choose.
after that. when I using command to generate the zImage, it couldn't pass. I get some fault like as:
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- menuconfig
drivers/net/dm9000x.c:305: error: `na_dm9000_irq' undeclared here (not in a function)
drivers/net/dm9000x.c: In function `dmfe_probe':
drivers/net/dm9000x.c:362: error: `na_dm9000' undeclared (first use in this function)
drivers/net/dm9000x.c:362: error: (Each undeclared identifier is reported only once
drivers/net/dm9000x.c:362: error: for each function it appears in.)
drivers/net/dm9000x.c: At top level:
drivers/net/dm9000x.c:291: warning: 'dmfe_debug' defined but not used
drivers/net/dm9000x.c:295: warning: 'debug' defined but not used
drivers/net/dm9000x.c:296: warning: 'mode' defined but not used
drivers/net/dm9000x.c:785: warning: 'dmfe_reset_dm9000' defined but not used
make[2]: *** [drivers/net/dm9000x.o]Eroor1
make[1]: *** [drivers/net] Error 2
make: *** [drivers] Error 2
How can I solve these problems!
THX!
0 项奖励
8 回复数
名誉分销商 II
506 次查看
it may be caused by the dm9000 component class name in your DEII.
please check your kernel include/nios2_system.h , find the port name of dm9000,
and update the na_dm9000 and na_dm9000_irq in drivers/net/dm9000x.c .
0 项奖励
名誉分销商 II
506 次查看
Thanks for your help, I could pass the compile now. And then, In Nios II 5.1 SDK shell , my uClinux system find ethernet now, in the start process, give me some relative message like this:
dmfe_probe:eth0, 50 Khz, Nios
<DM9000> eth0 I/O 80900090,VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 50 Khz, Nios
But now, in uClinux on my board, I typing: ifconfig eth0 192.168.0.100, it&#39;s give me some message like this:
ifconfig : socket: Address family not supported by protocal.
when i run ifconfig only, it&#39;s give me this message:
No usable adderss families found.
could you help me?
THX
0 项奖励
名誉分销商 II
506 次查看
--- Quote Start ---
originally posted by goral@Apr 13 2006, 10:38 AM
thanks for your help, i could pass the compile now. and then, in nios ii 5.1 sdk shell , my uclinux system find ethernet now, in the start process, give me some relative message like this:
dmfe_probe:eth0, 50 khz, nios
<dm9000> eth0 i/o 80900090,vid: 90000a46
      addr:  00:07:ed:00:00:00
dmfe_probe:eth1, 50 khz, nios
but now, in uclinux on my board, i typing: ifconfig eth0 192.168.0.100, it&#39;s give [/b]me some message like this:
could you help me?
THX
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14296)
--- Quote End ---
[/b]
--- Quote End ---
I am not good at network, may be other expert help out. or you should read the kernel source.
Did you enable those networking options in kernel config as step9 of the guide ?
0 项奖励
名誉分销商 II
506 次查看
Ofcourse I choose that support in step9, thanks the same to you, I will check it.
0 项奖励
名誉分销商 II
506 次查看
I have some advice,but not sure.
you can check your nios2_system.h and dm9000x.c,
na_dm9000 and na_dm9000_irq is defined in nios2_system.h,so which should be declared in dm9000x.c .
Best Regards!
FeiWu
0 项奖励
名誉分销商 II
506 次查看
Thanks for reply, My ethernet is working well now.
feiwu&#39;s and hippo&#39;s suggestion is very importmant for my trying.
THX
0 项奖励
名誉分销商 II
506 次查看
hi hippo
I wnat to add "ftpd" apps on my uClinuc OS.
When i make menuconfig then occur error info........
[jay@localhost uClinux-dist-test]$ make menuconfig
config/mkconfig > config.in
make -C /home/jay/uClinux-dist-test/config/scripts/lxdialog all
make[1]: Entering directory `/home/jay/uClinux-dist-test/config/scripts/lxdialog&#39;
/bin/sh: cc: command not found
>> Unable to find the Ncurses libraries.
>> You must have Ncurses installed in order
>> to use &#39;make menuconfig&#39;
make[1]: *** [ncurses] Error 1
make[1]: Leaving directory `/home/jay/uClinux-dist-test/config/scripts/lxdialog&#39;
make: *** [menuconfig] Error 2
But i excute "yum install ncurses" and don&#39;t install completing....
how to solve installing ncurses?
help me !!!
thx
0 项奖励
名誉分销商 II
506 次查看
--- Quote Start ---
originally posted by jay_1025@Apr 14 2006, 03:40 AM
hi hippo
i wnat to add "ftpd" apps on my uclinuc os.
when i make menuconfig then occur error info........
[jay@localhost uclinux-dist-test]$ make menuconfig
make -c /home/jay/uclinux-dist-test/config/scripts/lxdialog all
make[1]: entering directory `/home/jay/uclinux-dist-test/config/scripts/lxdialog&#39;
>> unable to find the ncurses libraries.
>> you must have ncurses installed in order
make[1]: *** [ncurses] error 1
make[1]: leaving directory `/home/jay/uclinux-dist-test/config/scripts/lxdialog&#39;
make: *** [menuconfig] error 2
but  i excute "yum install ncurses" and don&#39;t install completing....
help me !!!
thx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14343)
--- quote end ---
--- Quote End ---
Jay, you have to post this as another NEWTOPIC. it is in the upper right corner of the page.
0 项奖励
回复
