Hello!
I'm developing my custom peripheral component, wich operates with standard DMA from SOPC Builder. DMA should send data from SDRAM to my component. When my pheripheral component set to 1 endofpacket signal, transmition stops. But when my peripheral set to 0 endofpacket and set to 1 readyfordata nothing is happened. Why? How my component can continue data transmition? Thanks a lot!Link Copied
If the DMA controller is set up to stop on end-of-packet then you have to restart the DMA operation by setting the "GO" bit in the control register. You would normally do this from the CPU although I suppose any component that's an Avalon master could access the DMA controller's registers.
Andrew- Mark as New
Thank you, Andrew, I settle this problem
