DS-5 and JTAG server
Should the ARM DS-5 Debugger work through an Altera JTAG server?
In Eclipse, I do the following:
  1. Select the "Run -> Debug Configurations..." menu item
  2. Under "DS-5 Debugger", click "New_configuration"
  3. On the Connection tab, select "Altera -> Arria V SoC -> Bare Metal Debug -> Debug Cortex-A9_0"
  4. Change Target Connection to USB-Blaster
  5. In the Connections area, click Browse...
The Connection Browser window opens and displays an error:
"The script file ( device_browser.py ) failed during execution:"
Setup:
Quartus 14.0
ARM DS-5 5.18.0
Red Hat Enterprise Linux Server release 6.6
ArriaV SoC
Thanks for any help you can provide.
John
It does work. The solution was to add the Quartus linux32 directory (where libjtag_client.so resides) to the LD_LIBRARY_PATH environment variable. In the bash shell, this is accomplished by executing the following:
export LD_LIBRARY_PATH=<Quartus installation directory>/quartus/linux32:${LD_LIBRARY_PATH}
or, if the LD_LIBRARY_PATH variable is undefined, just:
DS-5 Eclipse must then be restarted.
