12748 Discussions
Dausing target processor: not responding.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
----------------these are the error message when i want to run a project on the
target board in the nios2IDE.
Then use the SDK,i try to connect the target,command "nios2-terminal",the responding show that it can connect .
Then i use the command "nios2-gdb-server" ,the error message :
then try the command "nios2-run ***" .it's message is "....... waiting for target .。。。。。。。。。。。。"  then it no repond.
I think others may come up aganist this problem too.
How are you solve that finally?
I've been having this same problem too. I get the error message:
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x01
I can program my .sof to the board no problem, I can compile my C application too, but when i go to run the C code on the processor I get that error message. I can't even use the flash programmmer to program the flash memory either, I get an error along the same lines as the one above.
If anybody has any ideas i'd greatly appreciate them.
