Debug using Active Serial
Hi
We use Active Serial programming using a ByteBlaster-II cable - this programs a chain containing an EPCS4 and a Cyclone.
Is it possible to use this for debug or must a JTAG cable be used?
[edit] I guess this document has the answer - we have to do both?
http://www.altera.com/literature/hb/cfg/cf...cfg_cf52009.pdf (http://www.altera.com/literature/hb/cfg/cfg_cf52009.pdf)
Hi Jason,
You must use the JTAG for debug. ASMI is just for programming the
config device.
You can program the epcs via the JTAG ... but you'll need to create
a flash programming configuration.
--Scott
