12748 Discussions
Different Applications On Common Nios Instances
I want different applications running on multiple instances of a common Nios design. How do I specify unique memory initialization files? Put another way, how do I specify a memory initialization file outside of Qsys?
(I rather not have two Nios designs and two BSPs, different in name only.)
// for example:
// two instances of "nios_cpu..."
nios_cpu cpu0 (...); // this one should use cpu0_mem_init.hex
nios_cpu cpu1 (...); // this one should use cpu1_mem_init.hex
Thanks!
(This question was formerly posted as "Unique Memory Initialization Files for Multiple Nios Instances" in the Nios General Discussion Forum but no useful replies were received.)
